-   -   Timing for SC camshafts on 930/66 engine...? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634399-timing-sc-camshafts-930-66-engine.html)
935TURBO 10-12-2011 12:50 PM
Hi everybody,
I need your advice and feed for the SC camshafts timing on the 930/66 engine with stock k-jet, K29 and B6 IC....?
Thanks.
Serge.
totle 10-12-2011 01:40 PM
Depending on where you want the power band.
Can be set from 1-1,7mm.
Set my previous to 1,65mm for god low and mid range power
cole930 10-12-2011 07:50 PM
I set mine at 1.6
Cole
935TURBO 10-13-2011 11:49 AM
Thanks......I'll try with 1.65......
fredmeister 10-13-2011 03:54 PM
As another data point I set mine at 1.45 to 1.5mm. I have a 3.4 liter with 36mm ported heads and stock CIS with k27S turbo.
I make boost almost immediately and the car pulls hard all the way to 6000rpm and probably more. I typically shift about 6000-6200rpm and notice no drop off in power.
Fred
