Boost Pressure Sender
I have a question for those of you who ditched a stock 930 intercooler, intake manifold and boost pressure sender. Are there any non-stock boost sender that would work with a stock boost pressure gauge in the RPM cluster? I do have a mechanical VDO boost pressure gauge in place of a stock clock. I want a stock pressure gauge to be functional rather than seeing it pegged with engine running.
MikeD '87 930 |
Obviously there are a multitude of changes, but at least for many when changing out the interfooler there is typically a boss for the sensor on the new interfooler somewhere. Certainly that is true with the TK units.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Chain fence eating turbo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 12-08-2025 at 10:22 AM.. |
My car was already heavily modified when I bought this car 16 years ago. There's no provision for a stock type boost pressure sender. I don't really need it...thought it'd be nice to have a working stock boost gauge even though it may be inaccurate. I was hoping to find a small simple boost pressure sender to tee it to one of the boost/vacuum line.
MikeD '87 930 |
What the heck is an interfooler? I must get one! Heh heh...
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I don't imagine you'll find some after market sender that will work with the stock gauge. Would need to have the correct internal resistance for the gauge to be accurate.
Related but different question — if there are any other sensors that work, is there any way to get the stock gauge to read more accurately? Mine is wildly inaccurate compared to my aftermarket boost gauge, it’s definitely for looks only.
Exactly that. I, too suffer from the stupid stock boost gauge, it reads way less than actual boost.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
That's unfortunate for those who upped the boost!
MikeD '87 930 |
Mike,
You would have to weld a port somewhere on the IC or intake manifold to install the stock sender. Where are you getting the boost signal for your mechanical gauge? Perhaps you can rig a connection there. To un-peg your stock gauge, you would have to find the single wire that normally goes to the stock sender...and ground it. That should return the gauge to zero. As for any old after market sender that would work with the stock gauge, that's a long shot since most all electrical gauges...be they boost or oil pressure, etc. come as a calibrated set. The senders have an operating "curve" whereby the internal resistance changes/increases as pressure builds and the gauge reacts accordingly.
