Parts list for 964 Turbo Rear Trailing arm conversion
As stated. I have a 91 C2 Turbo and want to convert the rear trailing arms to the "narrow" set up in order to fit larger wheels. Does anyone know the list of parts I will need? Will any narrow body 964 Trailing arm work? Thanks in advance. Tate
You will need:
(1) One pair of C2/C4 trailing arms (2) One pair of C2 half shafts (3) A C2 sway bar Looking at the PET, it appears that C2 and C4 arms were common but half shafts were not. Also the C2 sway bars were a little bigger in diameter than the C4 sway bar. The rear axle struts (where you would adjust camber and toe) are also common. Last I heard the going rate for these parts from dismantlers was $1000. |
I did the conversion on my car. It is the best mod you can do to the car look wise not to mention for performance reasons:) You will need NA rotors as well
Email cory@planet9eleven.com and tell him Eric Hood sent you. He might have everything you need! He is an honest guy so no worries:)
For what I use the car for I did not see any problems. My car does not run most of the time anyway:)
| All times are GMT -8. The time now is 01:09 AM. |
