Quick tuning question, does ignition timing affect afr's?
I'm in the process of tuning my engine finally, I'm curious to know if ignition timing and the air fuel ratios are completely independent of each other or if an adjustment in ignition timing will alter the afr's? Initially my afr's are 15.1@ no load cruise and 10.5 11 ish@1bar, 3k through 6k rpm. THanks
Tom |
yes. higher timing will result in a leaner mixture and lower timing a fatter mixture
thx. by higher timing you mean more advance?
Yep, poor timing = poor combustion = sub-optimal AFR's
| All times are GMT -8. The time now is 06:43 AM. |
