1980 930 euro trans,..LSD...fluid
what is the best fluid that you guys recommend for a 1980 930 euro trans with LSD,..
i have read alot of back and forth about synthetic,.. i have alot of royal purple 75/90w left from a trans swap in another car, its synthetic, not sure if this would work... is the swepco that everyone talks about synthetic? i am assuming in this also, the pull the fill plug first? just in case of anything bad...never the drain plug first! |
Smart quod bastardus
Pull the fill plug first to make sure it comes out. Good idea. As far as Swepco, it is a semi synthetic from what I have read on it. Certain tranny builders should chime in here to give their advice since it carries more weight than the other opinions on the net. I have been using the Swepco in my 79 turbo 4 speed with LSD and have not noticed any problems in 30k miles so far. Hope I am doing the right thing.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Porsche-Poor
Hey Jim, I have an '83 euro and running the Kendall (non-synthetic, NS 75/90 or something) with some Lucas LSD additive per the recommendation of John Walker, car shifts like butter and like it a lot more than the Swepco I was running for what it's worth
1979 911 RS clone hotrod 1983 930 turbo-sold, will be missed 1992 964 C2 Coupe-regrettably sold 1980 911 SC Weissach-regrettably sold 1975 911S-sold but not forgotten |
I'm using Kendall LSD 80W90. I think about the only place to find it is thru Jegg's @$5/qt.
Charles 88 911 Cab 74 TR6 88 CRX Si 79 930 #632 (sold her and survived her) |
any different users out there? picking up my rebuilt tranny on friday, and still looking for the right fluid
do yourself a huge favor... just put in 4 quarts of this and forget about it. Pelican Parts - Product Information: KEN-LSD-7745
I used the Kendall 75W90 LSD and got it from Jeg's as well.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
I was curious and checked out Jegs.com and the exact same kendall gear oil is $5 more per quart (you need four of them) there than right here from pelican...
Glocker Oil 33256 Kendall Axle Gear Lube Pelican Parts - Product Information: KEN-LSD-7745 |
I have used Mobil 1 gear lube in every trans I have owned and rebuilt. Never had issues with leaking or grinding. Good stuff, easy to find and does not stain your floor green
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
I have been using Penzoil 80w90 non synthetic with the GM limited slip additive.
It has been working well for me.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al Last edited by Hirevtuner; 12-29-2011 at 06:23 AM.. |
I did not know Pelican sold Kendall or I would have bought it here.......
Am I the only one left using SWEPCO? I have 210 in mine (I used to put 201 in my 911sc). It seems to work good but I haven't compared with KENDALL
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
I used some synthetic 75/90 from wall mart when i was out of town and needed to add some. I was impressed much better shifting than just the swepco. but mine isnt a lsd model.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
BTW, I may bump into you at Gary Fairbanks on Friday. I'm dropping mine off in the AM sometime. PM me and let me know when you'll be there.
Ken 1986 930 2016 R1200RS |
