plug size
Need help to source a couple of plugs. I used this donor manifold for my build, which has a couple of fine threaded tapings I need to close. I can't locate any plugs this size. Help needed locating plugs or fittings to plug these 2 holes. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Is this size maybe drilled for a timesert ? Anyone?
I have a manifold that had the port for the EGR drill and tapped for an npt fitting.
The other port in the top picture loos like it is the one that is supposed to have an aluminum fitting epoxied in the manifold. The fitting has two ports I believe one goes to the BOV valve and the other to the decell valve. Not 100% sure though it's hard to tell from the pic. Last edited by nocarrier; 01-03-2012 at 05:49 AM.. |
Nocarrier
Correct about the decel valve location, but I'm not running one and need to plug the opening. These are not tapped for NPT, there finer threads. Any ideas on how to plug? Philip
For the one that was for the BOV valve and decell valve, I would turn a plug out of aluminum and epoxy it in the same way the original was epoxied in there.
I would drill and tap the other hole for an npt plug. |
