Which shifter to purchase
Which shifter should I buy for my 930 ? I see two major types sold here I don't care how it looks just want the best correct shift possible.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Steve:
I've been real happy with my Wevo, would also suggest updating the coupling at the same time. Nite and day compared to the stock unit. The Haggard and FabCar are probably the very best but I would say for track use only. They sit on top of the tunnel and are completely exposed and they set the shifter higher. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
We'd say WEVO. Absolutely top-notch quality and performance.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Love mine
Roland 930 Turbo '81 Too many modifications to list |
i have a hargett in my 78 930 and really do like the position. i do not have an emergency brake but you can have one in place if desired.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp |
Yes !!!!
Hargett / My bad Thanks Roland Cole
Sorry to say about the Hargett
but firts of all its very difficult to get the gears in right position.
If you woud like to use the reverse in a normal way, you have to buy a softer spring for the reverse mechanism. Then you have to be very precise with alignement , so that the first shift feels like you use a stick in a jar can, but the rest of the shifts are good. Better to have a loose first shift than 3d or 4th Then we have the quality of the components, pure rubbish I used it for 2000 km then I have to ask a mechanical company to totally rebuilt the mechanism with real bushings and harder material. Everything was loose and unprecise after just 2000 km. I dont know about Wevo, my friend has Fabspeed and he is very happy with that. |
How's the conversion on the black car coming? Brendon |
I have to agree with the return spring, had to change mine, otherwise I would have bent the lever soon...
Shifting is harder, but more precise than before, but it needs a little training and fine alignement So if you like it more comfortable, it's the wrong shifter for you
Does anyone have any feedback on one of these for a G50?
Fantastic for the G50, too. Nice tight shift pattern, but very precise and just the right amount of heft.
I went with a Wevo and the coupler about 5 years ago. 2nd had been hard to get into coming down for years. Totally cured the problem. It certainly isn't a short shifter but is way more precise.
63 356 So Called Outlaw 76 930 |
Wer bremst verliert
I have a Hargett in the race car with a G50. I like the look and the position of the shifter, and the action is good.
It was delicate to set up. I'd like to see a different attachment method between the rod and the shifter/transmission. The use of grub screws allowed the rod to slip and lose adjustment. Also the steel rod rusted. The U joints also develop surface rust. I havent used a Wevo. The Seine in the Targa with a 915 works fine.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Well, my concern is that I am also moving the engine and trans forward, so a custom lenght rod will have to be made.
Sorry for thread jacking to OP.. |
hey brendon, the 2nd generation shifter seems much better to me. i have one of each. the secret is to get the cup of the shifter properly aligned so that the movement to engage reverse is very slight. once you find the sweet spot it is really a nice shifter. the black car is basically done...approximately 500 breakin miles!
Chris, just to be sure are you referring to the Wevo or Hargett?
http://www.youtube.com/user/pdqcarrera |
sudo apt-get purge 930
I have a Hargett for sale. WTB-- OEM 930 4 SPD Shifter or Trade Hargett for Wevo
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Ya +1! lin7310948, what are those wheels & sizes? Looks awesome.
