1986 930 R&R and light "while' I'm in there". Light.
As posted elsewhere, my starter ring developed a bad spot and the starter would simply grind rather than spin the engine over.
http://gallery.me.com/yorktown6/1000...13252839020007 The trans was also beginning to grind in the 1-2 and 2-3 shift, so I elected to drop the engine/trans and address some oil leaks at the same time. http://gallery.me.com/yorktown6/1000...13252839010007 http://gallery.me.com/yorktown6/1000...13255290320001 The transaxle went off to Gary Fairbanks in Norwalk, CT. Gary is one of those dying breed types- an absolute treasure trove of knowledge and no apprentice or son that is going to take over the business. I actually asked his permission to take a video of his workshop- there are thousands of porsche-exotica trans and differential parts on shelves from floor to ceiling. I feel fortunate to have met him, learned from him, and had my box renewed there. He changed the syncros, sliders, swapped my first gear with a different one, and installed a new second gear. Everything else checked out. http://gallery.me.com/yorktown6/1000...13260650220001 Then the engine went on to the engine stand with the 201 tool from our host. It is a leap of faith to think that those two nuts on the trans studs will hold the entire weight of a complete 930, but it does. The way the ring goes around the case, it distributes the load across a lot of the engine. http://gallery.me.com/yorktown6/1000...13260650160001 Out to the driveway, and pressure washed the engine compartment and engine itself even before disassembly. This will make the rest of the work on both that much cleaner to start with. Had a little assistance from my helper, first pressure washing then air drying the engine assembly. http://gallery.me.com/yorktown6/1000...13260650340001 http://gallery.me.com/yorktown6/1000...13260650290001 You can see a fair amount of Brian's exhaust here. It's a great setup. I'm eagerly awaiting his heat exchangers to come out. I'll have an easy go of it, mock installing them on the stand before the engine goes back. http://gallery.me.com/yorktown6/1000...13260650350001 |
Nice post gsxrken. Love the exhaust. How does it sound? Did you cut your valence to fit the other tip or is that aftermarket?
hey bud, nice meeting you at Garys that day, yes he is a dying breed. He has more knowledge and know how in one hand then most shops have anymore...
it cracked my up that he actually still looked stuff up in manuals and books and not google or his Iphone... your progress looks great, what are the plans for the motor |
The exhaust sounds great. Prior to this, I had the stock HE’s but replaced the stock muffler with a single magnaflow hanging off the turbo. It was a deeper tone that just didn’t sound like a Porsche, but it did seem to add some seat of the pants kick. This full exhaust has a raspy tone, pretty mellow at idle, but it rips when you get on it. It also woke up the engine; earlier boost, lighter weight, better looks, and sounds great. I’ll flip it over on the stand and post a pic of the underside later tonight. Search under my user name from about two years ago for the install thread.
Regarding what I am doing to the engine- hopefully nothing. it’s primarily fix the oil leaks from Wayne’s 101 book. I had to drop for the starter ring and trans work anyway, so I ordered a new sound pad and just about every gasket, o-ring, and leak-prone sender that I could identify. Clutch was still well within spec, repacked my throwout bearing, and I’m replacing all the intake gaskets and vacuum hoses I can find. I know from a 2011 valve adjustment that my studs are all intact, so I’m not looking to open a can of worms with other while-I’m-in-there’s. Hopefully I can stick to that. (This project comes at a somewhat inopportune time, as I am waist-deep in some major mods to my other toy with some hard deadlines for track dates this spring.) |
some progress and some questions
Got some more time to get further into it.
Stripped it further down so I can really pressure wash it: http://gallery.me.com/yorktown6/1000...13266578240001 Swapped the rear main seal: http://gallery.me.com/yorktown6/1000...13266577610001 What am I supposed to do with this? Looks like the pipe slipped off the fitting... http://gallery.me.com/yorktown6/1000...13266578590001 While the alternator is out to a local starter/alternator shop for renewal, what should I do to refinish the fan and fan housing? I have a glass beader that would clean them up nice... any pros or cons for using it? Then what? http://gallery.me.com/yorktown6/1000...13266578400001 Right at the wrong time, my compressor decides to "throw a rod" ! http://gallery.me.com/yorktown6/1000...13239837710001 http://gallery.me.com/yorktown6/1000...13239837430001 |
My crankcase vent hose did the same thing. Just use a short length of fuel safe hose and two clamps. If you want to get fancy you could have an AN fitting welded on.
You can bead blast your fan and housing but they will continue to corrode as they are magnesium. I'm planning to powder coat mine but surface prep is key. Much better that your compressor tossed a road rather than the 930! |
I'm hoping the oil mess at the front of the engine is attributable to this simple breather hose problem. I'll be flipping it over and plugging the air injection ports some weeknight this week. |
Tonight I was able to extract the air injection fittings. It looks like one of them burned or broke off the tip. I think it happened in the past, because the jagged tip is all dusty white like its been super hot. Lord knows where the bits are, but they must have traversed the turbo, right? FOD? I don't have any complaints with the turbo.
http://gallery.me.com/yorktown6/1000...13269356880001 |
I glass beaded the fan and housing, had to order a new Bosch alternator, and was able to degrease the rest of the engine. I used Gibbs penetrating oil on the fan and housing as I am not the polishing type. Reassembly should be able to begin after Wednesday when my (latest) Pelican order arrives. It's tough being on the east coast- it always seems like there is a wasted weekend in between me and my parts.
http://gallery.me.com/yorktown6/1000...13278732870001 http://gallery.me.com/yorktown6/1000...13278733420001 The entire assembly is much cleaner than it ever has been in the 10 years I've had it. I don't think anything was leaking from the case, but if I do have any further leaks, it should be much easier to determine where they are coming from. http://gallery.me.com/yorktown6/1000...13278737530001 |
Nice job!
I love to see people cleaning there engines ,are going to plug your air injector ports ? Great job
Clean is good. Sometimes I ponder taking the engine out of my 930 to remove and clean stuff even though it runs fine. Crazy but true.
how did you make out with gary buddy
One of the amazing things is how much oil these engines can drip on the stand. NO MATTER how long I let it drain, when I spin it some other way, by the next morning, a ton more oil has come out. And it never hits the drain pan! Quote:
I'm probably a few weeks away from getting the car buttoned up before I can render an opinion on his work, but I have no doubt. He showed me some pretty well worn parts and second gear's cage bearing was smeared/swiped and the gear was turning blue. He was surprised it didn't seize and said I was lucky my starter/ring gear went when it did! |
Curious what your trans work is costing. I've got an 88 930 with 66,000 miles that just now begins to grind when shifting from 1st to 2nd unless I'm VERY careful. Thanks!
930slant, PM sent on that transmission work. Careful that a little problem doesn't get bigger on you...
Poking around in the garage as time permits. Today (Saturday morning) is usually prime time but my son needed 6 stitches in his scalp. I installed the injection plugs with some red loctite- hopefully they stay. I have another order of loose ends in my Pelican project list (a useful feature, by the way) and I think I'll order another two just to have on hand in case one ever backs out. I have been soaking my injectors in techron for two weeks but some of them still don't have a 360* mist pattern when I hit it with the air gun. I decided to extend the pintle valve with some tweezers and wrap a little wire around it to keep it extended/unseated while it soaks. After some more soaking, I should be able to blast some air in the opposite direction. http://gallery.me.com/yorktown6/1000...13283972450001 |
Gsxrken, if your injectors turn out bad, I have six us injectors, I have had ultrasonic cleaned and tested - all OK.
They are from a complete cis i bought. I thought i was going to turbo charge my carrera 3.0. Not happenning. Nice work |
Quick question- I've got the engine reassembled but still on the stand, and noticed that the fan touches the housing at the 5 o'clock position of the housing. I did not paint or powder coat anything, so it's not related to that. It's a brand new Bosch alternator so it's not bearings. The housing locates in the pin at 6 o'clock, and then the clamp tightens it up. I don't seen any adjustment. I've loosened it up and attempted to tap it over, but it seems to only want to sit in one spot.
Any ideas or procedures to center the fan housing? |
Perhaps a thin shim or washer between the alt studs and housing at the 5 o'clock position will augment the alt and fan towards 11 o'clock.
