twin plugged targa's Avatar
How accurate is stock boost gauge/sensor
How accurate is the stock boost gauge?
Mine is showing boost of 0.9bar in temps of around 45F
I just had a new pressure sensor installed - maybe that is the culprit?
Prior to that it showed around 0.7 bar which I think is more normal?
any info appreciated
Ben
PS I believe engine is stock
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 01-23-2012, 08:06 AM
River Rat
Dave 86 930 Fl's Avatar
I have the stock gauge and I also have an aftermarket gauge in the clock location. Both gauges indicate peak (.9) bar pressures accurately. Not so sure off peak is the same.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 01-23-2012, 11:16 AM
Thanks- I thought a stock WG spring only took the turbo pressure to 0.7 bar?
Ben
Old 01-24-2012, 01:30 AM
mark houghton's Avatar
Ben
I too have an additional gauge besides the stock one, and both seem to read the same or very close to eachother.
Stock boost is .8 bar.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 01-24-2012, 05:40 AM
will cold weather take the boost past the normal 0.8bar as she definately went to 0.9bar indicated!
Should I worry?
Or just continue to monitor
thanks
Ben
Old 01-24-2012, 12:36 PM
