How accurate is stock boost gauge/sensor
How accurate is the stock boost gauge?
Mine is showing boost of 0.9bar in temps of around 45F I just had a new pressure sensor installed - maybe that is the culprit? Prior to that it showed around 0.7 bar which I think is more normal? any info appreciated Ben PS I believe engine is stock
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
River Rat
I have the stock gauge and I also have an aftermarket gauge in the clock location. Both gauges indicate peak (.9) bar pressures accurately. Not so sure off peak is the same.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. Last edited by Dave 86 930 Fl; 01-24-2012 at 04:29 AM.. |
Thanks- I thought a stock WG spring only took the turbo pressure to 0.7 bar?
Ben
Stock boost is .8 bar.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
will cold weather take the boost past the normal 0.8bar as she definately went to 0.9bar indicated!
Should I worry? Or just continue to monitor thanks Ben
