-   -   new build and improvements (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/655243-new-build-improvements.html)
herman maire 02-09-2012 07:31 PM
Very nice.
Does the X brace just mount to the front latch panel? What is the cost for just the porting?
vas930 02-09-2012 07:39 PM
Originally Posted by xbmwguy (Post 6548606)
Hey Vas isnt there a little drama with these cars whatever you do?! i had a single shock tower brace before and it helped, but this changed huge!!!!! highly recomend this upgrade:eek:
Thats true. :)
But what has it changed?
How does it feel to the single brace?
More direct in the steering?
Want some feedback before I buy.
Thanks.
pkracer21j 02-09-2012 08:41 PM
Damn Frankie...I guess I need to get started on 935-001...lookin good bro!
juicersr 02-09-2012 08:47 PM
Originally Posted by herman maire (Post 6548667)
Very nice.
The X-brace is secured to the front of the chassis via tabs on each side which are bolted in at stock mounting points.
http://forums.pelicanparts.com/uploa...1328848523.jpg
speednme1 02-09-2012 09:07 PM
Hey Juice, so the X brace is a complete bolt on? Will installation affect alignment?
juicersr 02-09-2012 09:10 PM
Originally Posted by Miguel Antonett (Post 6532343)
Prrrrreeeeetttty cool!
Just remember to keep the front valance heading forward... all the time. Have fun!
Ouuuuchhh Miguel! I still remember the look on your face when u and Vicky came around the corner:D
<iframe width="420" height="315" src="http://www.youtube.com/embed/fnTMP8J7-Gw" frameborder="0" allowfullscreen></iframe>
Awesome work Frankie. Can't wait to see the final numbers on this beast, esp on E85
juicersr 02-09-2012 09:24 PM
No welding is needed, it is completely bolt in. The strut tower plates mount at stock points, so will not affect alignment. If you are running extremely agressive camber settings, the plate mounting holes may need to be slotted slightly.
66cal912 02-09-2012 11:06 PM
Hey, Juicer that video is epic, was that in the maroon 934 rep car?, if so I cant believe it came around with the meats that are on it... talk about ohhh **** time..
Back to Xbmwguy's blowzilla thread, awesome build, look forward to seeing this build come together!
Maybe you guys can make a cross country trip out to Cali or Vegas sometime! Was hopin to see some of your cars a RRIV, but I know its a haul...
krasuskyp 02-10-2012 05:37 AM
Originally Posted by 66cal912 (Post 6548948)
Hey, Juicer that video is epic, was that in the maroon 934 rep car?, if so I cant believe it came around with the meats that are on it... talk about ohhh **** time...
Peteski & I ahead in the Skittle, Frankie/Dokktah in the Spinning Bullet, Miguel/Vicky sitting astonished in the sexxxxxayest(est) Brown gem you'll ever see having a headlight match with the Bullet.
amazing times, Bill 'n Ted's Excellent Adventures
Frank! Build is looking niiiiiiiice... good going, you must be just sillygiddy.
"Enjoy" (muwahahaa)...
xbmwguy 02-10-2012 05:47 AM
hey paulie, just telling office manager about you AND yiur fake teeth at cmp! cant wait to see you in spring (even though its 80 here in so fla)
willtel 02-10-2012 06:46 AM
Looking good!
I know you said you are planning to "take it easy" on your stock bottom end. Any idea on what power levels you will see before you decide that is enough?
xbmwguy 02-10-2012 08:16 AM
i will be in upper 500s when build is done next week but hoping that with only running 11.5# of boost til i do bottom to be in the low 5s. next yaer 3.5 pistons and barrels and beefed up bottom end will be it for me
juicersr 02-10-2012 01:27 PM
Nah, that was filmed by me while riding shotgun with Frankie BEFORE installation of the x-brace;) (but AFTER one helluva nite:D).
SCHNELE 02-10-2012 04:39 PM
Hello Gang, Frank the heads are beautiful, good luck with the final assembly. I think you may be firing your car up around the same time mine is finished.
xbmwguy 02-10-2012 05:53 PM
link i know you are chompin at the bit to get back in it! good luck also and hopefully we can get together again for some more good times
gsmith660 02-10-2012 06:44 PM
Was that your car that took the spin in the video? That was cool the X brace is on my list of things to do.
