i Flippin give up....rear torsion bar help...pleeeease
ok, 1980 930, car was corner balanced and lowered about 6 years ago, so i am assuming the torsion bars were removed at this point?
i am converting the car to coilovers so i need to get these out,...
the rear spring plates, came right off, no problems at all, bushings are GONE...nothing left...no worries
i have spent the last 3 hours fighting with ONE torsion bar, both of the torsion bars are loose and wiggle back and forth quite a bit... actually really loose, just wont pull out
sprayed with oil, let sit, NOTHING
i have 10 minutes away from welding a chain to it and putting my car in reverse...my luck, my 930 will be draggin down the street with me...torsion bar intact...
any help is greatly appreciated
i have rear some threads, and all see to have great ideas if one car is already out...
Old 02-01-2012, 02:29 PM
Max Sluiter
Flieger's Avatar
You tried tying a rope around the end and yanking real hard?
Old 02-01-2012, 02:46 PM
dude, i had a my dogs rope toy, thing is like a inch thick...NOTHING
Old 02-01-2012, 02:49 PM
IMR-Merlin's Avatar
Jim,
I had the opposite problem. My torsion bars were stuck in the outer bushing. When I tried to pull the spring plates off, the bars came out with them. I ended up drilling a pilot hole in the bushing cap to break it apart.
Are you planning on selling the torsion bars? If not, can you get to them with a big pair of channel locks? Since mine came off the oppsite way, I am not sure how far they are in. But once you get one out, you can use a long piece of rod and punch the other side out.
Old 02-01-2012, 02:55 PM
Max Sluiter
Flieger's Avatar
C4? Or maybe good ol' Nitro
Old 02-01-2012, 02:57 PM
Champagne on Beer Budget
HelmetHead's Avatar
Don't that year Tbars touch in the center? what about tapping one to loosen the other..then long broomstick the other out?
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 02-01-2012, 03:04 PM
IMR-Merlin's Avatar
this....
Old 02-01-2012, 03:05 PM
Originally Posted by IMR-Merlin View Post
this....
its great there are so many solutions to get torsion bars out, once one is already out, but how the F do i get the first one out,...i just tried beating it with a sledge hammer, it did move a hair
they are so loose, they just wont pull out (woops, thats what she said)
Old 02-01-2012, 03:14 PM
IMR-Merlin's Avatar
any luck buddy?
Old 02-01-2012, 04:22 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
From under the car drill at the center of the torsion tube a 3/16 hole and tap for a grease fitting. Install the grease fitting and use the thickest weight lube you can get the heavier the better. Then pump the fitting with your grease gun and it will simple hydraulically push either one of the bars out once one is out re-insert the loose torsion bar and make a simple plate that bolts to the torsion cap to prevent the free torsion bar from coming back out and continue pumping the lube to the fitting and this should push the remaining one out. After that losen up the make shift plate and remove the first torsion bar.
It changes from time to time.....
Old 02-01-2012, 04:30 PM
Max Sluiter
Flieger's Avatar
Well, have you tried heating the tube and then yanking? Or you could drill the middle of the tube for a zirk if you could find where the gap between the bars is, then pump in grease for a hydraulic removal.
Max Sluiter
Flieger's Avatar
Originally Posted by GJF View Post
From under the car drill at the center of the torsion tube a 3/16 hole and tap for a grease fitting. Install the grease fitting and use the thickest weight lube you can get the heavier the better. Then pump the fitting with your grease gun and it will simple hydraulically push either one of the bars out once one is out re-insert the loose torsion bar and make a simple plate that bolts to the torsion cap to prevent the free torsion bar from comming back out and continue pumping the lube to the fitting and this should push the remaining one out. After that losen up the make shift plate and remove the first torsion bar.
Ha, we posted at the same time but you beat me a little bit.
The issue I see with it is finding where the two bars end. The splines are continuous and so you can't be sure that the middle area is not covered by torsion bar splines.
Old 02-01-2012, 04:32 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
No big deal since he isn't going to worry about the bars just keep drilling til it atleast it is into the tip of either bar and when he pumps the lube it will make one or the other move even it it is dead ending into the bar. The lube will find its way to the cavity between the two and make them come apart.
Old 02-01-2012, 04:36 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Old School seems to always come to the rescue when you exhausted trying technology. LOL
Old 02-01-2012, 04:38 PM
Max Sluiter
Flieger's Avatar
I think a torch and rope is easier than tapping a bunch of holes in a thick steel tube. Or some sort of gear puller mechanism.
Old 02-01-2012, 04:41 PM
pete3799's Avatar
I had a he!! of a time getting the spring plates to let go of the TB's. so i was expecting a fight to get the TB's out of the tube. Not so.... just kept wiggling up- down to and fro and pulled them both by hand.
If all else fails the grease fitting idea should work.
Pete
79 911SC RoW
Old 02-01-2012, 04:46 PM
pdqcarrera's Avatar
Curious, can you get a bearing puller in there?
Old 02-01-2012, 05:08 PM
update....
i had a buddy heat the **** out of the torsion tube on the drivers side while i tied a rope around the bar and a comealong bolted to the side of my garage, and POP! took a lot of pressure...
the drivers side bar looks great, no rust, greasy as all hell, not sure why so difficult to get the Fout
these are red in color. is that factory? or are these aftermarket? i dont see any markings on the bars...
i will try and work back on the passengers tomorrow, that is the one that is giving me the most trouble
Old 02-01-2012, 05:31 PM
jsveb's Avatar
Great.
Mine are red as well. I think they are stamped at the end.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 02-01-2012, 05:35 PM
Metal Guru
911nut's Avatar
Now that you have one bar out, the other is easy. Take a long rod and stick it in the driver's side hole. If it's long enough, it will contact the passenger bar from the back side, yet hang out of the driver's side hole. Now tap it out.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 02-01-2012, 07:16 PM
