VDO boost gauge install question
Did some searches and seems there are some problems with accurate boost reading on the gauge that replaces the clock. I have a unit that was installed by Andial many years ago on another car and I want to put it on my 930. I didn't take pics of how it was hooked up other than it was hooked up in the engine bay. Any suggestion for where to hook up in the engine bay for a 78 RoW 930? I don't want to do the brake booster thing. It looks easier, but I haven't seen consistently good results. Seems there is some "lag".
Thank you for the feed back.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 03-14-2012, 08:37 PM
Brando
quattrorunner's Avatar
I used the one in place of the clock and it's plumbed to the intake manifold. It's very accurate and better than brake booster. I ran the boost line all the way back through the tunnel and into the engine compartment. instant response.
Turbo powa!
1977 911s. it's cool
Old 03-14-2012, 10:18 PM
b930's Avatar
Cant see any lag thats worth worrying about with t'ing off the brake booster. I run a variable vane turbo that spools fast as anything out there and don't see much lag at all with this set up.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 03-15-2012, 04:21 AM
cliyde's Avatar
No detectable lag with my VDO gauge when compared to the digital one. Have analog plumbed to brake booster and digi to manifold...surprisingly accurate piece of kit.
Old 03-15-2012, 05:53 AM
