-   -   Poor Idle when cold (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/665649-poor-idle-when-cold.html)
JGC930 03-14-2012 11:26 PM
Poor Idle when cold
My car idles really low maybe at around 500 rpm when cold and as it warms up it comes to a normal 900-1000 what could be happening?
It also has a lot of gas smell when starting
I have a freshly rebuilt stock WUR
Alan L 03-14-2012 11:46 PM
Two thoughts.
You really need to verify your cold pressure. This requires specific gauges /fittings.
Also you need to check your auxiliary air valve is working - ie is opening when the vehicle is cold. This lest the extra air in your engine may be looking for.
Alan
mooney265 03-15-2012 06:01 AM
Like Alan said: AAV valve...
heliolps2 03-15-2012 06:10 AM
what year is your car and Is your car stock and does it have any of the smog stuff on it , and do you have a dual vacuum distributor, I had the same problem as did J930 here on pelican and I was able to help him out on this subject, Your WUR and AAV may fine, Let me what we are working with first an if you have a pic of your engine bay would help,
JGC930 03-15-2012 09:44 AM
My car is an '81 and is completely stock, I think my problem is the AAV it is not opening completely, I replaced it with a used one I bought but it is still not working properly, where can I source a good one?
RarlyL8 03-15-2012 11:17 AM
Jose, before replacing parts you should verify function.
- Verify the voltage getting to both WUR and AAR.
- Remove the AAR, note % open, place in refrigerator and again note % open.
- Put gages on CIS and verify cold pressure and system pressure are in spec.
- Verify no vacuum leaks.
- Verify the cold start injector is not leaking.
I assume it is hot where you are. If the cold pressure is a touch low or the CSI is leaking you will have these symptoms. AAR malfunction will reduce idle but not cause rich smell.
