Poor Idle when cold
My car idles really low maybe at around 500 rpm when cold and as it warms up it comes to a normal 900-1000 what could be happening?
It also has a lot of gas smell when starting
I have a freshly rebuilt stock WUR
Old 03-14-2012, 11:26 PM
Alan L's Avatar
Two thoughts.
You really need to verify your cold pressure. This requires specific gauges /fittings.
Also you need to check your auxiliary air valve is working - ie is opening when the vehicle is cold. This lest the extra air in your engine may be looking for.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-14-2012, 11:46 PM
Tinkering Pays!!
mooney265's Avatar
Like Alan said: AAV valve...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 03-15-2012, 06:01 AM
what year is your car and Is your car stock and does it have any of the smog stuff on it , and do you have a dual vacuum distributor, I had the same problem as did J930 here on pelican and I was able to help him out on this subject, Your WUR and AAV may fine, Let me what we are working with first an if you have a pic of your engine bay would help,
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 03-15-2012, 06:10 AM
My car is an '81 and is completely stock, I think my problem is the AAV it is not opening completely, I replaced it with a used one I bought but it is still not working properly, where can I source a good one?
Old 03-15-2012, 09:44 AM
Crotchety Old Bastard
RarlyL8's Avatar
Jose, before replacing parts you should verify function.
- Verify the voltage getting to both WUR and AAR.
- Remove the AAR, note % open, place in refrigerator and again note % open.
- Put gages on CIS and verify cold pressure and system pressure are in spec.
- Verify no vacuum leaks.
- Verify the cold start injector is not leaking.
I assume it is hot where you are. If the cold pressure is a touch low or the CSI is leaking you will have these symptoms. AAR malfunction will reduce idle but not cause rich smell.
Old 03-15-2012, 11:17 AM
