89 930.
Benny771's Avatar
Question WUR Ohms, 89 930
Anyone know off the top of their head what resistance i should be getting ?
28 ok?
0 438 140 153
No power, cold that is
Old 03-18-2012, 09:19 AM
mark houghton's Avatar
No, not off the top of my head. But since I happen to have a spare 0 438 140 153 hermetically packed away...and I've got nothing better to do today....I whipped out the trusty VOM meter and got 39.4 ohms. Hope this helps.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 03-18-2012, 02:10 PM
89 930.
Benny771's Avatar
yikes..... What does this mean?
what are the draw backs if it is not in spec? Car seems to run fine,and I'm just about to turn it into an adjustable wur.
Old 03-18-2012, 08:31 PM
With lower ohms, less resistance, I think that means that it will heat up a bit quicker - thus not staying in warmup mode as long. I have a different serial number WUR (earlier year) that I had made into adjustable, it's in my car, and it has a lower ohm reading than my #153. Since installation, I've always felt that the warmup period is a bit shorter.
Funny why your and my exact same WUR's have different readings. Maybe it's our ohm meters, or dirty connections on my WUR, or age affecting the resistance.
Personally, Benny, I wouldn't worry about it. If you've been running with this WUR all along, then it will react the same when modified to adjustable relative to how long it keeps the warmup period control pressure low.
Old 03-19-2012, 06:04 AM
89 930.
Benny771's Avatar
Thx again Mark, mine is now adjustable and i will try it out tomorrow.
You are always a big help.
Old 03-19-2012, 07:11 PM
