-   -   Where to mount O2 sensor (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/672893-where-mount-o2-sensor.html)
Ken911 07-27-2012 11:09 AM
mine is a GHL duel out with no internals i put mine in the passenger side tube. Doesnt work below 2k unless i block off the other outlet. keeps sucking fresh air past it and i have 4 inch tips so to block the other side off i have to put a large soup can over the end and clamp it with hose clamps. When i do my EFI swap i'll be moving it to the spot between the turbo and the muffler.
xbmwguy 07-27-2012 01:00 PM
no when you go efi we will do a real muffler set-up and ditch the tin can. ;)
philip j 07-27-2012 01:06 PM
muffler outlet side
I also have my O2 sensor on the muffler outlet side. I think when I install mt new turbo, it will go before the muffler. It works well where it is, but on cold startup it take about 15-20 seconds before I get a good reading. I think this is because it takes longer to heat the sensor. This didn't matter with cis, because the AFR adjustment wasn't there. Now with the efi I can adjust AFR every 250 rpm's and would like to know how rich I am running at startup. http://forums.pelicanparts.com/uploa...1343419577.jpg
02fly 07-27-2012 01:17 PM
Originally Posted by billjam (Post 6701473)
Mine is about a foot from the end of the tailpipe (which isn't fitted in pic).
I fitted a simple heat shield to protect the wiring from heat radiated from the turbo.
It is very easy to access in this location for the occasional calibration.
http://forums.pelicanparts.com/uploa...1334997749.jpg
http://forums.pelicanparts.com/uploa...1334998016.jpg
Any chance on getting a shot of the back of your car I love the slotted bumper
