Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Where to mount O2 sensor
Guys, I am getting a Innovate MTX-L to measure AFR and need some advice on the best location to mount the O2 sensor? My exhaust is a full B&B unit.
Also, will I need a heat sink?
Thanks,
Old 04-20-2012, 07:14 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Turbofrog
smurfbus's Avatar
Just before the muffler after the turbo at 10 to 2 a clock. For longevity it's best to use a heatsink but some have seen good sensor life without it also.
79 930: HX40super, WMI, J&S+retard gauge, 123dist, MSD6A, BLWur, BB headers, Tial46/0.8bar, 2*044, AIC-1, LM-2 + AFR gauge
99 Audi S4: 'sleeper' family hauler, 170mph standing mile, 11.8 qmile
2005 Aprilia RSV Factory: Big Bore kit, Full Acra race TI exhaust, PC3 with map/cyl
Old 04-20-2012, 09:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Thanks for the quick feedback.
I spoke to Innovate and they were confident that I dont need a heat sink.
Old 04-20-2012, 11:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
mark houghton's Avatar
I was scared about heat sink and short lived sensors, so chose to mount mine in the tail pipe as close to the muffler as possible (for me, that's about 14 inches from the end of the pipe). I do not believe it's causing any erroneous high (lean) readings due to being so close to ambient air. Plenty of exhaust flow to prevent mixing with free air.
Mark H.
1987 930, LSD, B&B shortneck Intercooler, K27 7006 turbo, Tial WG, Kennedy Stage 1 PP, HKS boost controller to 1.0bar, Boost recirc manifold delete, BL adjustable WUR w/boost enrichment delay, LC-1 AFR and G3 analog gauge, Greddy boost gauge, MSD6AL and 8762 boost retard ignition, K&N cone air intake, Fabspeed single outlet muffler
Old 04-20-2012, 12:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Certified User
billjam's Avatar
Mine is about a foot from the end of the tailpipe (which isn't fitted in pic).
I fitted a simple heat shield to protect the wiring from heat radiated from the turbo.
It is very easy to access in this location for the occasional calibration.
Bill
1988 Carrera - standard for now, but there's a 3.6 engine (with ITBs, COP, MS3X) sitting in the corner ready to go in, and a whole set of turbo body panels waiting in the attic.
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 04-21-2012, 12:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Jeeze Bill, you need to throw some dirt on that thing or be accused of owning a garage queen!
I really like the slotted rear valence...aesthetically and functionally.
Mark H.
Old 04-21-2012, 05:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
So I have a dual exhaust B&B, see pic. Not crazy about mounting in the short pipe between turbo and muffler but if i mount after the muffler which side? and will that provide accurate data?
Old 04-25-2012, 12:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
zaidigonzo's Avatar
mine is after muffler(single outlet rarlyl8) about 7 inches before tail pipe. when i let of the gas the afrs climb to high 17-19 for a split second.... Is that cause of mixing?? I hope so..............................................
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS
K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam
Old 04-26-2012, 04:27 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Happiest when Tinkering
gsmith660's Avatar
Yep probably so innovate told me to use a 1 inch bung and I put mine in the same location as Billjam did and I also wrapped mine with heat sleeve and have seen no ill effects with stable AFR's
Old 04-26-2012, 07:00 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Hey Bill, how do you know if it works or not?
That turbo/exhaust looks like it has never been cranked, as well as the WG muf, the pipe is not even discolored...
Old 04-26-2012, 12:13 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
gsmith660's Avatar
Mine works fine.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 04-26-2012, 06:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Here is the response I got from Innovate:
"I suggest welding the bung on the pipe furthest away from the turbo, on the right hand ride after the muffler. Also, if you use a clock as reference, the sensor should be between 10 o'clock and 2 o'clock, with 12 o'clock being the best position.
Since the sensor is going to be right by the end of the tail pipe you will get false lean readings until you put the engine under load and build exhaust pressure.
Regards,
Felipe Saez
Innovate Motorsports"
Old 04-27-2012, 10:47 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
gsmith660's Avatar
Same guy that told me where to put mine I really don't think I get any false leans in this position except maybe for an instant when I first let off the throttle
Old 04-27-2012, 12:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
orac69's Avatar
Im really sorry if this is a dumb question - but im not a mechanic and I am just slowly learning - please bear with me...
I have a Fabspeed dual-out very similar to the B&B pic in flat_6 post.
So can you confirm - I need to physically drill a hole in the actual stainless steel pipe?
Is the "bung" then welded into that hole, and then does then the sensor / cable attachment screw into that?
Thanks!
UK 1981 930, RHD. K27, Fabspeed Headers & twin out muffler, Kokelyn IC, Turbosmart Eboost EBC, Pro W/G. BL Adjustable WUR and RPM Solenoid.
2007 Viper SRT/10. *Twin Turbo coming soon :0)
Old 07-26-2012, 06:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
I've gone native
Tt surgeon's Avatar
My fabspeed headers have a bung after the turbo, I used that port, seems to work just fine.
1987 930 Slant 505
Andial IC, Andial K 27 7200, 1 bar spring, Fabspeed, Permatune.....fast n scary
Old 07-26-2012, 07:09 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Ronnie's.930's Avatar
Thanks!
Yes to all of the above.
Old 07-26-2012, 08:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
FYI, I now have mine install and it works great in the left tailpipe directly after the muffler. I used the left as the exhaust flows significantly more out of that side. I could tell by hand on a cold start up the temps was much hotter.
Old 07-26-2012, 11:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
orac69's Avatar
Flat_6, can you tell me - did you purchase the data logger box (I forget the model number) to go with the MTX-L gauge? Im wondering exactly what else I really need...
I assume if I dont have one, I'll have to tune with the laptop plugged into it constantly...
Old 07-27-2012, 12:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
IMO, the data logger box is great for the track. If you just need to tune then the laptop is fine as you shouldnt be tuning on a daily basis. Once your car is dialed in, enjoy driving and use the AFR gauge as quick reference to ensure no parts have failed.
Old 07-27-2012, 04:29 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
Followed instructions
I followed the Innovate instructions, had bung welded in just before the Zork tube bent down, did this in 2007, built recommended copper heat sink, sensor has lived through a couple hundred dyno tests and lots of track time at vintage races and Porsche events...
Best,
Dr. Stephen J. Hummel, P. Eng.
Old 07-27-2012, 04:51 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
