b930's Avatar
turbo oil supply check valve operation
Was hoping someone could describe how the simple ball / check valve in the oil supply line to the turbo works? I understand the ball floats and with pressure under it, it lift up against the lower side of the special banjo with slots in it so oil bypasses. Now with the engine off, how does the ball stop oil running to the turbo? does it just sit on the seat with gravity?
If the oil in the tank is at a higher level than the ball, will the head of oil not just push the ball off the lower seat?
Just trying to figure out how it works and what it was designed to do. I know many report of oil continuing to flow through the turbo with the engine off without the ball installed.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 05-01-2012, 06:13 AM
Smart quod bastardus
fredmeister's Avatar
I think it is meant to stop oil from draining out the turbo oil supply pipe and back into the engine case via a siphoning effect.
This way the oil pipe is not bone dry on restart starving the turbo momentarily.
The oil in the sump should have no way of getting back into the case unless it works its way past the oil pump gears and even then I think it would take a while to fill the case back up this way.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 05-01-2012, 05:11 PM
I've gone native
Tt surgeon's Avatar
where in the oil line is the ball anyway?
Old 05-01-2012, 05:36 PM
Banned
It is in the fitting assembly that also incorporates the low oil pressure idiot light switch.
Old 05-01-2012, 06:03 PM
The ball is a factory check valve of sorts and as Fred noted
primartly used to prevent siphoning. The ball was a stock item
in all the turbos and it's 9mm in dia. The spring is not a stock
item but is used in instances where excessive oiling is present
in the turbo. The spring is used on top the ball to adjust the
flow to a lesser amount.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 05-01-2012, 06:11 PM
I've gone native
Tt surgeon's Avatar
Thanx
Old 05-01-2012, 06:14 PM
b930's Avatar
Ah right, I think I have it now. If is was to stop oil syphoning out of the oil line to prevent dry start ups of the turbo then it all makes sense. I saw some threads saying that without it the oil drip tank would full up on shut and could not work out how it prevented this, but syphoning back makes sense as it seats in the cone on the bottom side, preventing this.
Was the sping under the ball a factory fitment? That would in theory then prevent it from acting as a check valve against syphoning.
Old 05-01-2012, 11:06 PM
xbmwguy's Avatar
no thats not a factory fitment and i think cole meant "spring on TOP of the ball" to apply slight pressure to seal better.
Old 05-02-2012, 02:53 AM
Thanks xbmx !!!!!
I edited my post.
Cole
Old 05-02-2012, 09:47 AM
b930's Avatar
Got it, cheers
Old 05-02-2012, 04:45 PM
Anybody have specifics on the spring? I am having excessive oiling.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-07-2015, 07:49 AM
gavinc69's Avatar
So its like when you put a straw in your drink then put your finger over the end of the straw and lift it out, the liquid in the straw stays in it.
So when the ball bearing sitting in place is like your finger and the oil in the pipe to the turbo stays put like the liquid in the straw!
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 09-07-2015, 11:37 AM
Alan L's Avatar
I don't think it is designed to restrict flow to the turbo. It is designed to cut off siphon supply after shutdown. Otherwise you can end up with a puddle of oil on the floor via the turbo. If you have excessive oiling (presuming this means out the back of turbo or in your intake system) more likely an issue with turbo seals. Or your scavenge system has an issue.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 09-07-2015, 12:45 PM
