-   -   AFR readings normal? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/681092-afr-readings-normal.html)
forte500 05-31-2012 07:25 PM
Put in AFR gauge this past weekend......pointer stays perfectly in range 10.5 - 11.5 in 3r - 5th gear (G50)....1st in 2nd reads 14+ on full boost. I suspect it's because the readings don't have time to normalize in lower gears but wanted to see if anyone else observed this??
Motec maps show everything is normal...
oilonly 05-31-2012 08:51 PM
I don't know what is normal but I can give you my readings.
Warm up 10.5 then quickly to the 11's.
warmed up at 900 rpm idle - 13.8
cruising around -14 to 15
boost events drops it down to low 11's.
quattrorunner 05-31-2012 10:48 PM
Mine are at high tens low elevens in second, I don't have time to look in first. Third fourth and fifth full boost always stay between 10-11.5. 14 full boost is too high. Is your gauge digital? A moving needle might be reason for slow actuation I guess. Mine is 915 gearbox.
rodolf 06-01-2012 12:38 AM
10/11... You are as rich as in CIS !! Why ? Do you have tried with an AFR of 12/12.5 ? What was the problem ? EGT too hot ? Knock ?...
My values, with 3.4, EFI, GT2 cams, big turbo and 0.9bar boost :
Idle : 13.5
Cruise : 12.5/13
Boost : 12/12.3
quattrorunner 06-01-2012 06:11 AM
Cruise for me is 14-15
Richard930 06-01-2012 07:29 AM
Mine cruises nicely at 15 - 15.5ish. Idle 13.5, mid 11s on boost
DeFreest 06-01-2012 03:43 PM
Richard930, With the A/F ratio your running what do you see for gas miliage?
The required picture. Just picked it up 3 months ago and have added Brians adj WUR and it runs much better. Thanks Brian!
Donhttp://forums.pelicanparts.com/uploa...1338590448.jpg
Richard930 06-02-2012 12:06 PM
Nice car! I haven't done any highway trip for quite a while but figure I would probably be in the 11 l/100km range which is about 20 - 21 mpg. My normal driving, which is mostly city commuting with occasional highway and full boost runs only gets me about 12 mpg.
JBurer 06-02-2012 01:21 PM
Frank,
It's possible that's the case, but I don't experience that with mine.
Your comment at the end regarding the Motec maps, can you explain what you mean by that?
Tippy 06-02-2012 02:59 PM
That is severely lean for boost being in the 14's. My Innovate is said to sample 1000 X's a second so there shouldn't be any lag in the readings. Of course the digital display samples less than that but it still should be nearly instant feedback and accurate.
