Bright Green Newbie questions
I am the new owner of my first Porsche, a 1988 930 Cab.
Worked great last fall, put to bed over the winter with fuel stabilizer. Did a little maintenance work over the winter: Air and fuel filters, new plugs. Now have a max turbo boost hesitation and a week ago it started stalling when the engine warmed up (unable to maintain idle). Takes a few minutes downtime before it restarts, but still will not idle when hot.
Going through the "sticky" describing the failure to start issues and noticed a few things that I hope someone can shed some light on.
1. The manual says the Turbo only has one fuse in the engine compartment left side (Heated rear window, rear wiper return) except I have a Cab so obviously don't have these. I do have two fuses, both 25A (different colors though so what gives there?). 3 red wires, one feeds both fuses which have a buss bar across them on that side, the other two leave the other side with one heading towards the front, the other vanishing into a wire bundle. Question: What are these circuits?? The Carrera has 2 fuses for heater blowers (1 25A and 1 16A). Could it be for heater blowers????
2. While pulling out the fuse panel, I noticed two orphan plugs: One looks an awful like the plug that goes into the O2 sensor but that is already plugged in (see pic). The other is a square plug. Question: what are these?? are they just orphans from a standard wire harness that is used across multiple markets and models therefore has these orphans lying about?
3. In making sure all hoses are tight and leak-free, I found a red, small diameter hose coming from just above the butterfly. It goes around the engine to the firewall but just hangs in space in the engine compartment. Question: is this supposed to be there just sucking ambient engine compartment air in or has it come unplugged from someplace (cam;t see where).
Many thanks for any input. Really enjoying joining the "pelican flock".
Old 06-02-2012, 02:36 PM
Banned
For question #3 - look at the second diagram in this link . . . I bet this is the hose that goes from the throttle body to the thermal valve (#7) . . . this is part of the cold start circuit . . .
Need some help, Vaccum lines and fuel line
JFairman does a good job of explaining what this component does in paragraph #5 of this post -
Help with vacuum/air lines
Old 06-02-2012, 04:54 PM
Red Vac Line
Thx Ronnie.
Sounds like you are right. Will check later today.
This car was originally from California and from what I can read, the line was probably disconnected by a PO post-emissions testing there. The car already passed Canadian emissions tests so I'm not concerned about that. I might re-connect it just to see if it helps my "won't idle when hot problem", although I'm thinking it won't.
..J
Old 06-03-2012, 06:38 AM
Banned
One thing you will need to check is that if this hose is disconnected from the thermal valve, that a new/custom hose is running from the throttle body port to the distributor vacuum advance pot (or the vacuum advance mechanism will not work) . . .
Old 06-03-2012, 08:38 AM
Needed mirror-on-a-stick to find it, but located the spot where this plugged in on thermo valve. Looks all stock and everything seems in it's place and tight. Thx ronnie
Old 06-03-2012, 11:55 AM
Tags
930 , boost , stall , turbo , wiring
