-   -   wondering on building a TT without the intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/682206-wondering-building-tt-without-intercooler.html)
James Brown 06-06-2012 10:49 PM
the engine (unknown at this time) should make enough power to push a 70ish, 2000lb car around well. But, needs a no tail or duck tail only rear. Just thinking out loud here, nothing chipped in stone. Or, thinking on a water-cooled intercoolers? thoughts?
turbo breathing easy should beat a PMO/FI maxed out engine.
some must haves:
-twin small turbos
-twin plug
-electronic FI/engine management
-light weight
-bling (show and go, lots of polish)
-uniqueness
-good client "hefty budget"
-350-400+ shp
Flieger 06-06-2012 11:58 PM
You can do bent or split intercoolers that fit under a ducktail. It has been done on a few cars. I think you can also fit a normal 3.3 930 intercooler under a Burzel if you trim the shrouding way back.
totle 06-07-2012 12:22 AM
Always liked the way RUF did on their CTR.
Nice and clean engine compartment, and will fit without any rear spoiler.
Oil tank need to go and upgrade engine with 993 oil filter etc
Been looking at this and found that 996 intercoolers might be used
http://i867.photobucket.com/albums/a...8_green_11.jpg
clutch-monkey 06-07-2012 12:55 AM
how does the ruf setup get airflow through the coolers? always wondered.
totle 06-07-2012 05:30 AM
I have wondered about the same thing. So can unfortunately not help here.
Hope some other will explain.
Tt surgeon 06-07-2012 05:40 AM
Why not just get a 993tt?
mfyoung1086 06-07-2012 06:55 AM
water to air would be the best setup for a compact area, but you'll need to mount the water cooling rad somewhere for the power you want to make though they wouldn't need to be big
MarkRobinson 06-07-2012 09:07 AM
How about a single air/water intercooler, put the tank in the back, the exchanger up front.
ALL the twin turbo Lamborghini's are using air/water IC's now.
HelmetHead 06-07-2012 11:37 AM
I believe the ruf has two vents on the rear fenders which feed the intercoolers
TurboKraft 06-07-2012 12:09 PM
That was on the early cars, but later when he had access to wind tunnel testing he found at speed air was coming *out* of the NACA ducts on top of the fenders.
The airflow over the top of the car provides a lot of flow into the engine compartment.
(Provided it is a genuine wing or similar quality, not the cheap aftermarket louvers that flat leading edges.)
quattrorunner 06-07-2012 12:25 PM
use low compression to not use intercoolers, wait, 350-400hp.....O-yeah, Ok you'll need intercoolers but 2000 lb.? My conversion to turbo added enough weight alone without intercooler and decklid spoiler to lower the rear of my77 911s so that would be dificult to reduce weight enough to get to 2000lb. That is a pretty tough request. Two turbos will add more weight.
RarlyL8 06-07-2012 01:16 PM
What is shp?
350whp should be easy with a stock 3.3L block with engine management and a couple K16 turbos at 0.8bar. Stick the air/air IC under the tail and have fun. Engine should weigh around 400lb with the right gear. The rear mount headers I have for this application weigh 15 pounds. Side mount is more work/money same weight.
9dreizig 06-07-2012 01:46 PM
just water/meth inject it ,who needs an intercooler?
Chris did this in his 356 turbo
Reaper930 06-07-2012 02:25 PM
Look at Paul's 934 tribute, IC is in the rear quarter behind the wheel with a screen. Works well enough for a 934 would work perfectly with your setup.
James Brown 06-07-2012 03:19 PM
lots of good info, thanks guys. sorry that should be HP Rarlyl8 (old aircraft mechanic). the CTI is a good start. trying to cram all this in a 73. The 993tt could be used and backdated, another way to go most of the engineering already done.
JBL930 06-07-2012 03:34 PM
The majority of the stock CTR wing is blanked off, there is just a portion open above the air intake..... I think, and it is just a thought, that with a good seal around the bottom of the engine, and a good seal around the engne lid, the intercoolers are relying on the engine fan and pressure in the wheel wells pulling/pushing air through the intercoolers......
The only CTR with the Naca Vents is the 'original' yellow bird, and it wasn't deemed efficient enough for production cars.
I was in a modified (Ruf modified) CTR earlier this year, and had a good look around it, the only way those intercoolers are getting air across them is the engine fan pulling air through like it does with a stock car...... That and them running rich as hell
911TT33 06-07-2012 07:23 PM
some must haves:
-twin small turbos
-twin plug
-light weight
-uniqueness
-350-400+ shp
You should be able to get close to 400HP on a EFI 3.2 Carrera base motor running 0.5 - 0.6bar (without an intercooler), twin plugged, twin turbo's and aftermarket programmable EFI.
Lots of single turbo'd non-intercooled setups like this on this forum developing around 360HP.
TurboKraft 06-08-2012 06:54 PM
Did someone say twin turbo with no rear wing?
http://forums.pelicanparts.com/uploa...1339206817.gif
James Brown 06-09-2012 12:28 PM
I see i am not the first to think about this!! thanks chris, perfect!
TurboKraft 06-09-2012 03:53 PM
Based on a 1995 993.
Twin Garrett ball bearing turbos
Twin compact air:water intercoolers -- could do one across the back, but we also thought this layout looked really cool and it is serviceable with the tall runner 993 Carrera manifold.
Twin heat exchangers up front, with twin coolant pumps, single reservoir.
Original configured with a draw-through MAF, like a stock 993 Turbo, and lowered compression. It did about 365hp/380tq at the wheels at 0.6bar boost -- same as a stock 993T but less boost, and more torque in the lower rpms (<3500).
If you run a Ducktail spoiler, there can be a lot of room for a split core air:air intercooler. It depends on your manifold.
Call, email, or PM if you want help with the build.
copbait73 06-09-2012 05:01 PM
If you side mount the twins you will need a '72 oil tank and system.
If you rear mount the twins, turbines opposed, your valance will only give you room for straight out pipes - really loud.
Mount the twins to the rear compressors opposed and you can work in some muffling.
The "G" body, '74 up, rear bumper added critical space for all turbo stuff you want under there.
Reaper930 06-09-2012 05:09 PM
I side mounted my TT 3.8 with a stock 930 setup FWIW. Before I saw the light and went rear mount, and yes its L O U D.
If you side mount the twins you will need a '72 oil tank and system.<br>
If you rear mount the twins, turbines opposed, your valance will only give you room for straight out pipes - really loud. <br>
Mount the twins to the rear compressors opposed and you can work in some muffling.<br>
RarlyL8 06-09-2012 07:44 PM
PW put together one of the most impressive no-tail presentations I've ever seen.
Yes it does have intercoolers in a place worth consideration.
http://forums.pelicanparts.com/uploa...1339296103.jpg
James Brown 06-09-2012 08:19 PM
thats a monster Brian, are the pipe lengths too long to have a front mounted intercooler? Oil tank relocation should not be a problem. maybe tone it down a bit so it does not look like a indy car!!
good stuff, keep it coming...
RarlyL8 06-09-2012 09:22 PM
P. Wong put that one together as an engineering project of sorts. I think he had a thread on it at the time (a few years ago). Crazy looking and must have sounded just as nuts!
TurboKraft 06-09-2012 10:07 PM
We find side mounting twin turbo easier, and makes for the shortest plumbing. Like the 993T.
You can keep re-use the factory rear mounted oil tank with easy, low cost mods. Then you have the whole bumper area for your muffler system.
Email or PM for pics.
Converting to a 964 or 993 oil tank isn't that difficult either, but not a requirement.
RarlyL8 06-10-2012 04:52 AM
... but rear mount retains the cool factor. http://forums.pelicanparts.com/suppo...ool_shades.gif
Also makes adjusting the valves a lot less time consuming. For me if you can't see the twins they aren't worth doing. To much cost/complexity for little to no gain.
willtel 06-10-2012 06:54 AM
This one fits under a 3.0 Turbo Carrera tail.
http://i57.photobucket.com/albums/g2.../ICfitted2.jpg
http://i57.photobucket.com/albums/g2...t/ICfitted.jpg
Reaper930 06-10-2012 01:46 PM
Or you can just go the backseat route :) works well enough for a K3...
http://forums.pelicanparts.com/uploa...1339360696.jpg
http://forums.pelicanparts.com/uploa...1339360779.jpg
http://forums.pelicanparts.com/uploa...1339361154.jpg
TurboKraft 06-12-2012 09:53 PM
Originally Posted by willtel (Post 6796353)
That intercooler setup looks familiar... Nicely done, sir! :-)
Bryan's 1974 Turbo RS 3.0
1976 Porsche 911 Turbo Carrera | Bob
http://forums.pelicanparts.com/uploa...1339563172.jpg
