Forte500
Valve Adjustment - post rebuild
About 3K on rebuild and would like to do my own valve adjustment...a few other things need attention while I'm there. Questions for group after reading posts:
- Best to use Backside method?
- Engine/Trans drop best approach (overall less frustration)?
- Anything special required for 3.4L high-perf motor?
- Anybody live in CT want to assist a 1st timer ($50/hr coaching fee)?
I have lift and all the tools, so thought it would be good to learn.
Frank
Old 07-23-2012, 03:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I did it the easy way... The engine was out.
It was my first one. Did it the normal way but use the Back way as a check after (Go-No Go)
P.S. The coaching fee normaly paid in Beer and Pizza
Who Will Live... Will See
Old 07-23-2012, 04:02 PM
Hi Frank,
Off topic - but did you ever get to the bottom of what was causing that 1st gear AFR question you had a few months ago?
Old 07-25-2012, 07:05 AM
Frank
Hi Frank. I don't quite trust the backside method but that's just me. There's nothing wrong with the standard route. Just have plenty of the feeler gauges on hand as they do get tweaked and should be discarded after that.
No call to drop the drivetrain just for a valve adjustment.
You could ask your rebuilder, but I doubt the spec changed for your 3.4. Different cams still seem to use the same spec.
A lift would make the oil change and lower valves much easier. But the top intakes are on the other side of the tin and have to be reached from topside. Remove Intercooler and bypass plumbing, air cleaner, and swing the AC compressor out of the way and you'll be fine.
If I helped, we'd have to do mine right after yours. That lift sounds nice!
Ken
1986 930 2016 R1200RS
Old 07-25-2012, 07:41 AM
Would you mind showing us a picture of the lift? Next on my "to do" list.
Old 07-25-2012, 10:53 AM
Forte500
Think it would be easier to drop the motor, as I need to do oil change, replace G50 shifter seal, and address a few other misc things. That said - Backside or Std Ways? Can I use regular plug feel -gauge?
John - the AFR issue was caused by over tightening the gauge bezel (pinched the needle)
Old 07-26-2012, 09:04 AM
JJ 911SC's Avatar
Definitely easier out. Do the normal one and you can use the backside as a Go/No Go.
For the normal way: you need one of them $5.40 + $6.40 for 3 extra blades; Porsche 911 & Carrera Filters & Belts - Page 4
Before you do start (either way), take a reading of the present state. Put the gauge in to see if thigh or loose and record it. Do that for the 12 valves, it will give you a feel for it.
Warning: If you have only 1 blade, it will break on the first or second one you will try to adjust. If you have 6 blades, like I had, you might be able to do all of them without breaking any... Murphy's Laws #911
Old 07-26-2012, 09:20 AM
Forte500
lol....thanks for the advice. I will take it!
For the backside GO/No Go a standard feeler gauge should work, yes?
Before, I do all this - does it sound reasonable to do a valve adjustment on a new motor (3K)? I hear most of the clicking when driving in a tunnel or next to the divider on the highway, but I may just be paranoid. HAHA
Old 07-26-2012, 09:56 AM
JJ 911SC's Avatar
You will need an ordinary 2.5 and 3 thousandths feelers for the GO/NO-GO gauges.
Pelican Technical Article: 911 Valve Adjustment - The Backside Method
Old 07-26-2012, 10:07 AM
Hah! That's the cheapest fix you'll ever find!!
Old 07-26-2012, 11:06 AM
Forte500
Yeah, I was happy to feel like an idiot for once (or twice)
Old 07-26-2012, 12:51 PM
Forte500
Is the lash/specs the same on all cams (964 vs. stock)?..mine is 3.4L with 964 cams.
Old 07-30-2012, 04:19 PM
beancounter
jwasbury's Avatar
I don't like the backside method. I also find the traditional method is a PITA. I really like this tool for the valve adjustment:The new 36-Degree Valve Adjusting Tool - Rennlist Discussion Forums
I believe the valve clearance should be the same for 964 cams as the factory spec.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 07-30-2012, 06:02 PM
Telerding's Avatar
Can you still get this tool anywhere? Last post on rennlist on this is over a year old.
1986 930, Garnet Red Metallic
Previous P's:
65 911, 66 911S
63 904 (086), 63 904 (038)
70 914-6
Old 07-30-2012, 11:02 PM
Chain fence eating turbo
It should be sold here
Old 07-31-2012, 02:16 AM
if the motor is going to be out anyway, it might be interesting to try adjusting them with a dial indicatorM assuming you own one. You probably could observe the .004 easily enough, even if it was just to verify your feeler work.
Ken
Old 07-31-2012, 02:55 PM
Ken911's Avatar
I tried the link it wouldn't open anymore. I have always thought this might be a better approach. Probably from doing so many small block Chevy's and Pontiac's with the engine running. Loosen until it starts clicking then tighten 1/4 turn while oil is splashing all over you new engine lol.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 08-01-2012, 09:08 PM
I do mine with a dial indicator, the same Z block indicator used for the camshaft timing. I do this with the motor in the car. No problem. Very easy and very very accurate. Works great. I would not recommend adjusting the valves on a Porsche motor with the engine running.
Old 08-02-2012, 03:21 PM
Ken911's Avatar
Duh, you do valve adjustments with the engine running on old chevy V-8's with hydralic lifters. Not on a 911. however the adjustment was measured by 1/4 turn past being loose. So the practice of backing off 1/10th of a turn from tight should be pretty accurate.
2019 Silverado 6.2L
Old 08-02-2012, 05:08 PM
Forte500
While the motor is out....anything else I should check besides valves....retorque heads? etc.?
Old 08-07-2012, 12:40 PM
