-   -   Does anyone have a passenger rear trailing arm that I can borrow for measurements? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/687264-does-anyone-have-passenger-rear-trailing-arm-i-can-borrow-measurements.html)
patina 07-05-2012 05:32 AM
I am having difficulty aligning my 930 and I think the passenger rear trailing arm may be bent. I am looking for a straight (never wrecked/damaged) passenger rear trailing arm to take measurements so I can determine if my trailing arm is bent and if so how much. Does anyone have one off their car that they won't be using for a couple of weeks? I have looked into trying to buy one but everywhere I look they are in the $1,000 range. Since I am not certain this is the issue I would hate to spend that only to find that mine is completely normal.
I will be happy to pay shipping both ways (obviously) and whatever you think is fair for the use of your part. To clarify the car is a '78 so I would need a 78-89 arm, the part number from Porsche is 93033151205.
Thanks in advance, any help is greatly appreciated. The car in question, help me bring her back to perfect!
http://i.imgur.com/wCRW0.jpg
JFairman 07-05-2012 07:53 AM
What is the difficulty? Might be good to check the trailing arm pickup points on the torsion bar tube for damage and the trailing arm and springplate rubber bushings that cold flow and change shape altering alighnment after 34 years.
Installing mono balls in the trailing arms in place of the origonal rubber bushings make it way easier to adjust camber in the rear suspension because instead of compressing old dry rotted rubber bushings to do that the spherical bearing in the monobal pivots allowing the trailing arm to rotate (like your forearm) during camber adjustments with no resistance.
The origonal rubber bushings will have collapsed and cold flowed away from their orgonal shape from the cars weight sitting on them the last 34 years so weather sealed monoballs in place of the old trailing arm bushings is a good upgrade.
They go for $200 from rennline and a little more from elephant racing. Pelican sells both.
patina 07-05-2012 07:57 AM
Thanks for the advice. My passenger rear camber is around -2.5*... the car is about a half and inch lower than Euro. I was told that was too much negative camber to adjust out/get it into spec. I know for a fact that this car was in an accident where it was hit in the passenger rear, so I am guessing that the PO could not see that the arm was bent (if it indeed is) and re-installed it.
onboost 07-05-2012 10:15 AM
pputkowski,
I would have to agree with JFairman on this.. very valid points.
Additionally, from what I've seen over the years on these cars after a hit as you describe, either the pick-up point is damaged as suggested above, or the trailing arm is broken. I've never seen a bent one, as they're pretty robust.
Good luck working it out!
patina 07-05-2012 10:30 AM
Originally Posted by onboost (Post 6840682)
pputkowski,
This is good news! Thanks!
patina 07-07-2012 07:31 AM
After further investigation I have found that my problem (alignment issues) was poorly diagnosed.
Took the car somewhere else, now she's good to go! Huge weight off my shoulders.
