EFI manifold question
I've been looking at various EFI setups for the 930 and have noticed that some use a 3.2 C manifold, some use custom, and some use stock 930.
Just curious: what are the differences/advantages/disadvantages, if any? |
Cost was a factor on my motor. Then again the cost of a custom or fabbed ic was also significant. I'll try to post pics later. Currently sitting idle on I-40 in TN.
E-85 sippin drunk
The 3.2L intake has bigger diameter runners, and also incorporates the fuel injectors and rails stock. If you use the stock 3.3L intake, you will have to buy custom Aluminum spacers to hold the injectors.... and when most people go EFI, they also open up the intake ports (although you dont have to), so the 3.2L intake is a natural fit.....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
carrera manifold
I have done it both ways, and the Carrera is only slightly more work. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
So is keeping the 930 intake more cost effective without sacrificing potential increases in hp compared to the carrera intake?
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam |
If I had to do it again, with a mild EFI project, I'd go with the 930 manifold to avoid my IC modifications. That being said, I got a killer deal on my IM, injectors, TB, etc.
87 carmine red 930 | 57k | B6 modified IC | GHL headers | custom exhaust | VEMS EFI | carrera intake w/ flipped TB | LS2 coils | EBC | K27-7200 (soon to be replaced by GTX3071 |
