Canucks Fan
Question Inter cooler question
I had a buddy weld up 2 stock inter coolers for my 87 930 and I'm worried about crap in the coolers from the job. I soaked them and wiped out what I could but I'm wondering if I should hook up my leaf blower to blow it clean or is this amount of air going to make a difference. I have access to big compressors at work but worried about the volume and pressure from these.
How much volume can flow through the cooler? what would be the max pressure that you would run through it?
Anybody else do anything like this before?
Finn
BTW, my buddy did a super job, total cost = $150 including the coolers (2)
From the Deep Dark Jungle
Old 01-28-2013, 03:57 PM
mark houghton's Avatar
Just fill 'em full of soapy water and drain several times. Front flush/back flush/shake rattle and roll! Compressed air is just going to take the path of least resistance and may not clean all the vanes equally. Anyway, large CFM would be the ticket if you do the air thing. As long as the exit end is fully open, you shouldn't have to worry about pressure buildup.
I guess if you're really concerned about welding slag inside, then install a fine mesh screen inside the exit end (before the throttle body) to catch any flakes initially. Then take the IC back off, check for any stuff, and remove the screen.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 01-28-2013, 04:15 PM
I've gone native
Tt surgeon's Avatar
Sounds cool, pic?
Old 01-28-2013, 05:03 PM
jsveb's Avatar
I believe rarlyl8 did this some years back.
As TT says, PICTURES
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 01-28-2013, 05:39 PM
I've heard of people stacking two stock IC's on top of each other but have never actually seen a pict of the result.
Old 01-28-2013, 06:33 PM
Banned
Here you go, Mark -
Cheap uprated intercooler, can it be any good?
Old 01-28-2013, 06:39 PM
Originally Posted by Ronnie's.930 View Post
Well $hit, there ya go! Ask and you shall receive. Thanks Ron.
Quite often you can find these stock IC's going for a song, but most likely people think they're worth their weight in gold (I think driven by the sand rail people running with Porsche engines). A couple-three hundred bucks and some labor to weld the two together gets you a B&B, or Garritson, or RUF, or whatever lookalike. I wonder how they flow?
Old 01-28-2013, 06:45 PM
I've gone native
Tt surgeon's Avatar
Looks freaking good!
'07 997.1tt
Blk/blk 600hp, bad to the bone
Old 01-28-2013, 07:25 PM
Interesting...is the top of lower and bottom of the upper opened up to allow air to flow through?
Yasin
Old 01-29-2013, 02:59 AM
kuehl's Avatar
If you wanted to test the welds and check for any lose items inside,
its common to use something that will simulate the environment.
This hand little gadget is a simple solution used by many R&D labs,
rated at 200 ft lbs of force, however lateral "G's" are not rated,
only requires about 5 cfm to operate, not sure if ear or eye protection
is included in the box though; paint can not included however not required
Old 01-29-2013, 03:51 AM
Canucks Fan
Yasin
Yasin, yes the top and bottom coolers are opened up to flow as one on mine, its a cheaper way to go and I don't think you'd get the same preformance as with a porpuse built cooler but it was cheap. I bought 2 coolers locally to me, 1 of them I got for free, just paid the shipping.
Sorry I don't have pic's, I don't know how to add them.
Thanks guys.
Finn
Old 01-29-2013, 04:00 AM
Bully's Avatar
Slick, what are you going to use as shroud material between the IC and the tail? I have been looking for something to close in my new larger IC?
betting yours was cheaper than mine!
Old 01-29-2013, 09:31 AM
