-   -   Griffith's AC upgrade for 930 install thread (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/692648-griffiths-ac-upgrade-930-install-thread.html)
gsxrken 08-04-2012 05:56 PM
I've had my 930 for 10 years and the AC has never worked. I had determined at some point that the compressor was bad and I just never did get around to an R-134 changeover. Maybe I'm getting older, but I just wasn't using the car as much as I could have because of the oppressive temps the black on black coupe gets up to in the summer.
Researching here and elsewhere, I decided it's been long enough and I wanted to nuke this once and drive the car rather than nibble around the edges. I called Charlie Griffith (Kuehl on this board) and we worked out a plan for my 86:
Kuehl Stage 3 System
The rearward mounted Kuehl Condenser with a blower fan attached.
Complete new barrier hose set for system integrity.
A high low pressure switch to help protect the system
Receiver Drier.
R134 conversion oil and charge port adapters.
New o rings for all system connections
Plus options:
Kuehl improved evaporator box gasket kit.
Kuehl Evaporator with expansion valve and improved gasket kit,
Duehl Kuehl Condenser with full time blower fan, stone guard kit, mounting and electrical hardware. (mounted in front of the rear LH tire)
Center Kuehl vent
Kuehl Thermostat
Kuehl Serpentine Front Condenser
Denso Compressor
gsxrken 08-04-2012 06:06 PM
I'm doing the install myself, as my schedule permits. I drove the hour to his shop in (way) north NJ and met him and his son. Had a great walkthrough of the shop and the parts that I was purchasing, as well as some pointers on the install itself. It's nice to be local enough, and I'll run back over there for the evac and R-134 charging when I'm done with the install.
So far I've tackled the smuggler box overhaul and the new thermostat. The thermostat was a pain in the ass.
I believe I am the first person since the Stuttgart crew in 1986 to open the smugglers box. It was very dusty, foam gaskets tearing as I removed parts, and some little Porsche part number stickers floating around in there.
https://lh3.googleusercontent.com/-C...8_+4_17_52.jpg
Here's a blurrier photo of the complete backache. Luckily I have recently replaced the two gas struts that hold the hood up, and have retired the Titleist 52* gap wedge that served for many years under there.
https://lh3.googleusercontent.com/-Z...8_+4_17_53.jpg
gsxrken 08-04-2012 06:19 PM
To get the front evaporator out, you need to remove the front floorboard to get at a little duct fastened to the firewall that projects into the box.
https://lh4.googleusercontent.com/-M...8_+4_17_53.jpg
This was a surprise... there is an amplifier fastened to the backside of the floorboard. Some hack whaled into to wiring harness in several places. I'm leaving it for another day for now; the radio doesn't work and the exhaust is loud. Up to this point, I've usually had the windows down when I drove anyway. That should change with the AC upgrade underway.
https://lh4.googleusercontent.com/-Y...8_+4_17_53.jpg
This is what it looks like once it's all pulled out.
https://lh5.googleusercontent.com/-G...8_+4_17_53.jpg
The little slide clips on the box are difficult enough to remove on the workbench. Charlie recommends ditching them and securing the two halves with some #4 screws for easier in place service of the fan in the future. I definitely concur. You'd never get the slide on clips on in the smugglers box.
https://lh4.googleusercontent.com/-o...8_+4_21_31.jpg
There's some gaskets and baffles that Charlie has developed that require some box prep work, but it's very straightforward work.
https://lh4.googleusercontent.com/-1...8_+4_21_32.jpg
Here's the new evaporator next to the original. Different construction and 25 years younger. As nice as it looks, I hopefully never see it again.
https://lh6.googleusercontent.com/-d...8_+4_21_31.jpg
torresmd 08-04-2012 06:24 PM
Thanks for all the pics. Keep up the great work!
bushle 08-04-2012 06:35 PM
A/C Upgrade
Thanks for sharing. I'll be watching your progress with great interest. Mine will need the complete rebuild. Especially after this Summer in the new dustbowl.
gsxrken 08-04-2012 06:39 PM
Swapping the thermostatic tube was tedious. First of all, it requires taking apart the cheesy console rack under the radio. Porsche left precious little extra wire length to work with. And the way the slots slide onto to each other was a truly frustrating experience. On my knees outside the car, reaching into the car under the dash, while getting occasional 2nd degree burns by my old school 75w drop light.
https://lh4.googleusercontent.com/-B...8_+4_21_32.jpg
There was some dremel work required to a little plastic divider between the AC temp knob and the AC fan knob to fit the new thermostat. Another tidbit that I hope to not have to see again. Here's the new one next to the old bastard. I taped some auto wire to the old one before I pulled it, so I had a snake to repull the new one with. But the thermostat is fairly stiff, and cannot be bent sharply, so it's not as easy as it sounds. But it is done.
https://lh6.googleusercontent.com/-y...8_+4_21_32.jpg
That's it for the first day. I hope that was the worst of it (and it really wasn't that bad, just physically tough from the contorting and bending over in the bonnet). I've got to read the directions to see what's up next in the sequence. He has the directions down to paint by numbers easy, probably to avoid all sorts of time-wasting phone calls into him. He did say figure on 8 hours to R&R the nearly 40ft of AC lines in the car. I just find that hard to believe, but I'll time myself for the heck of it when I get there.
Tt surgeon 08-04-2012 06:48 PM
Subscribed.
I've done the low budget version, r134 conversion with the new fenderwell canister and the keuhl center vent. Overall it's cool but not ice cold. Cost around 500 total.
quattrorunner 08-04-2012 07:16 PM
Yeah, sub for me.
1986 930 08-05-2012 04:04 PM
I am looking to do that on my 86 930 as well. I will be interested in your results. I think that I am going to do the 930 kit plus the new evaporator. I have the center vent already.
Good luck!
E Ray 08-06-2012 11:01 AM
Sounds just like my story.
I have had my car for 12 years, it originally had AC but by the time I got it the compressor had been removed, so everything else came off about 10 years ago, with the thought I will fix it someday. Like you I have not been driving the car much so I decided now is the time to fix things, I too talked to Mr Griffith and ordered pretty much the same set-up except I plan on deleting the deck condenser added the upgraded blower motor with variable speed and will be making my own hoses.
All my stuff arrived last Friday and spent a good part of the weekend figuring out how to put it all back together again, Got the AC box rebuilt and re installed along with the variable speed fan setup, hopefully I sneak sometime this week to test things out.
M5guy 08-06-2012 03:45 PM
I admire your efforts.
About ten years ago I bought the monster setup from Griffiths for a 76 930 I had. Triple condensers, all new hoses, compressor, evaporator - everything. I started to contemplate the under dash work, but then decided to have someone else do the entire installation.
The results were amazing. Laser temp was reading about 34 degrees at the vents. It would turn my knee caps blue.
gsxrken 08-09-2012 05:19 PM
OK- I got into a bit further today. I R&R'd several of the AC hoses, which isn't too bad because I've got the car quite high on four jackstands and have a nice Racedeck floor to just lay directly on. Most of the hose clamps, and there are many, are simple 8mm screws or nuts. The new hoses just reuse the same mounting points and hardware.
It's been said before, but the directions rock. And each part, each hose etc has a label on both ends for where it goes.
https://lh6.googleusercontent.com/-u...8_+9_19_43.jpg
And the kit is complete. For example, it comes with the wires, the wire shield loom, the wire connectors, tie-wraps, and each wire is labeled as well. Again, you're paying for the engineering and the thoroughness of the solution and directions, but you are never taking a part out of the box and scratching your head over WTH it is or where it goes.
https://lh4.googleusercontent.com/-Z...8_+9_19_43.jpg
I had two surprises today. First, I found some broken glass behind the leatherette rear seat side panel. Since the car was a bit of a creampuff when I got it 10 years ago from an MD in Cali, I was not aware that this was not the car's first rodeo. I don't know how the glass could have got where it was... even if the side wing window was broken (by a thief or in an accident) I don't know how it would have got down behind this panel. Troubling. Like an exboyfriend or something.
https://lh4.googleusercontent.com/-5...8_+9_19_44.jpg
The reason I had to go back there in the first place is that the frontmost condensor mounts to a longer seat-belt retractor bolt that you must install in place of the OEM bolt.
Here's the new longer bolt protruding into the wheel well.
https://lh6.googleusercontent.com/-S...8_+9_19_44.jpg
gsxrken 08-09-2012 05:35 PM
Two posts so I don't timeout...
The other surprise is that there is a little fan above the front condenser, and it doesn't work. I found it while R&R-ing the condenser, and when I tried to spin it by hand, the squirrel cage was very stiff. So I took 12V direct from the battery to the motor and no joy. Quick call to Charlie and he offered to swap the motor with a more powerful one, and free up the fan cage itself etc. So, boxed it up and sent off for that "upgrade".
This shot is from the floor looking up where the condenser would be.
https://lh5.googleusercontent.com/-N...8_+9_21_13.jpg
Here's a shot of the condensers: three bolts and it's out. Similar construction to the evaporator and the rear condensers that I'll post pics of in a minute.
https://lh3.googleusercontent.com/-X...8_+9_19_42.jpg
Here's the front wheelwell condensor that mounts to the seat belt bolt I mentioned earlier.
https://lh4.googleusercontent.com/--...8_+9_19_44.jpg
Here it is partially installed. The other mount uses one of the torsion tube cover bolts.
https://lh4.googleusercontent.com/-u...8_+9_19_44.jpg
I have one lousy image of the rear wheel well condensor setup, I'll put it up for now and then maybe add some better ones at another date.
https://lh5.googleusercontent.com/-q...8_+9_19_45.jpg
I know I said I'd keep track of hours for the hoses, but it turns out the job unfolds in entire related phases. So rather than change every hose and install the new bits, it's install this, remove that, swap the hose, and run this wire etc. I bet I did put a solid 5 hours into it today spanning 10 hours with all sorts of errands and interruptions.
Unfortunately, it needs to lay up for a bit now while I travel next week.
1986 930 08-10-2012 04:07 AM
Nice job! How hard is re-plumbing the hoses? I have this idea that it is going to be a real hassle to remove the old hoses and replace them. Your description does not sound hard, just time consumming.
speednme1 08-10-2012 05:40 AM
Wow! Great job Kenny, next year hopefully I will be upgrading mine. So your post serves as inspiration.
JFairman 08-10-2012 05:42 AM
Nothing difficult just takes time like you said.
If doing it at home you get to lay on the ground next to and under your car alot.
Safety glasses will help keep dirt out of your eyes while removing the old hoses, and if you're doing it in Florida during summmer a powerful fan or two for some comfort and bug spray for the mosquito's helps alot.
1986 930 08-11-2012 11:25 AM
I am going to mitigate the Florida Factor by doing it in October or November! Good call on the bug repellent though. While the rest of the country bakes we are getting rain every day. It is actually quite nice but the mosquitoes are getting bad. They are big enough to be assigned side numbers!
gsxrken 08-11-2012 03:06 PM
Sure does sound familiar. If I ever go with a full-bay intercooler, I may ditch the decklid unit, but for now it stays.
That's what I'm shooting for, too. Thanks for the feedback.
As Jim said, it's not hard. There is a lot of road debris that falls down especially under the front wheelwell area where the two lines go to the front condenser. But nothing is intellectually challenging.
In fact, I snuck out there for 3 more hours and banged out most of the rest of it.
Here's a shot of the line running from the decklid to the rearward Kuehl condenser.
https://lh4.googleusercontent.com/-c...8_11_18_42.jpg
This line goes from here all the way to the smuggler's box evaporator.
https://lh5.googleusercontent.com/-h...8_11_18_43.jpg
Two better shots of the rearward condenser, one of the lines runs to the other Kuehl condenser in the rear wheelwell, and the other goes to the decklid condenser. The install requires that you install the right angle sheet metal as a heat shield for the hose.
https://lh3.googleusercontent.com/-C...8_11_18_43.jpg
You can also get a peek at my virgin RarelyL8 heat boxes.
https://lh4.googleusercontent.com/-4...8_11_18_43.jpg
Here's the new dryer and associated lines to the evaporator and front condensor. It was rather difficult removing the old lines to the front condenser; they go over the water bottle and into parts unknown before they emerge at the front. After pulling from the wheelwell and cussing at them for quite a while, I cut them in half and pulled them from the front. I was dreading snaking the new ones, but it took 1/4 the amount of time it took to remove the old ones. Not the typical experience, but a welcome one.
https://lh5.googleusercontent.com/-K...8_11_18_43.jpg
https://lh6.googleusercontent.com/-U...8_11_18_44.jpg
One of the last things is to swap the hose fittings from the old compressor to the new one. I need to run to the hardware store for a schraeder tire valve stem removal tool to discard the R-12 sized fittings.
https://lh3.googleusercontent.com/-Y...8_11_18_44.jpg
I'm pretty much done. Unfortunately, I need to travel this upcoming week so it'll all have to sit.
JFairman 08-12-2012 07:04 AM
If you remove the fuel expansion tank behind the headlight bucket and big water tank for the wipers and headlight washers below it then you'd see how the AC lines going to and from the front condensor are routed.
Those two plastic tanks are held up in place with one bolt each. The 2 gallon water tank holds up to 2 gallons of water so support it when loosening the bolt on the strap clamp that holds it up in place so it doesn't drop down quickly possibly popping out or breaking off one of the 3 washer line nipples pressed into the screw on plastic cap on top. BTDT and repaired it with superglue.
The reason the origonal AC lines were really hard to pull out of that area is because the factory routed them behind the bracket that the front bumper shocks are mounted on. That was to hold them snug in place against the side of the chassis in that area and it's a tight fit.
You probably can't see that and you can't get your hands at them to feed the hoses through that spot while the expansion tank and washer bottle is in place.
Lots of road dirt and dust falling down and getting in your eyes and nose is the unpleasent part of replacing the AC lines. Other than that it's a satisfying job as you get it done.
Good luck with the AC.
gsxrken 08-13-2012 01:38 PM
Thanks Jim. As so often is the case, had I spent a little time up front and removed the thing blocking me instead of struggling around it, I actually would have saved some time.
One last note- I decided to check my decklid condenser for contamination and holy crow, I'm glad I did. A Q-tip swab came out pure gray. I bought some AC flush after checking with Griff on my options, and proceeded to flush and then use compressed air to clean out the condenser. The amount of fine gritty crap I got out was impressive. I'm glad the one original part that I am reusing will not be contaminating my otherwise entirely brand new system. I strongly suggest anyone doing an upgrade but reusing something of the old system perform the series of flushes to clean it out.
Here's the color of some of the flush I got out (and yes, the flush is clear in color) and remember, this is just from the smallish rear condenser.
https://lh4.googleusercontent.com/-b...8_13_17_22.jpg
gsxrken 08-24-2012 05:38 PM
Back from break and the installation is completed. I plan to head up to Griff's on Tuesday weather permitting for the evacuation and charging procedures. I'm glad he's local, because the yahoos around here would never buy into his recommended method of vac, purge, vac, purge, fill, drive etc. I can't stand letting anyone else touch my cars because of the good-enough-for-'gubmint mentality so rampant in the auto repair space. Hell, it's in just about every space...
Here's a shot of the collection of 26 year old stiff and dry-rotted lines.
https://lh3.googleusercontent.com/-D...8_24_21_+0.jpg
The new compressor installed:
https://lh5.googleusercontent.com/-E...8_24_21_+0.jpg
The rear condenser stone guards in place. You want to leave enough to protect the condenser itself but maximize airflow too for them to really work.
https://lh3.googleusercontent.com/-a...8_24_21_+0.jpg
https://lh4.googleusercontent.com/-g...8_24_21_+1.jpg
One last shot shows the center vent that replaces the "bow-tie" fitting on the front firewall.
Does anyone have any idea what the rubber hose is for? It is connected to a very small inline blower fan that was secured to the back of my ashtray. It doesn't seem to come on with the fresh air.
https://lh5.googleusercontent.com/-S...8_24_21_+1.jpg
Tt surgeon 08-24-2012 06:57 PM
That's the rubber sensor line that attaches to the sensor to the right of your steering wheel.
Setup looks great, in looking at it there is no way those condensors would fit a slantnose. bummer
JFairman 08-25-2012 05:54 AM
Why do you think those condensors wouldn't fit in a slantnose?
Is it the 1980's miami vice style slotted air vent in front of the rear wheels that's in the way?
I'm just guessing but if the duct on the back of it is in the way maybe it could be modified or reshaped to work with the AC condnesor feeding cool air to it.
It seems like the other condensor behind the rear wheel would fit the same with slantnose bodywork or regular 930 bodywork.
Also, there is no sensor to the right of the steering wheel for that hose.
The end of that hose hanging down slides on to a little round plastic air vent that snaps into a hole in the dash for the air supply to the thermostat for the problematic overengineered auto heat box.
The other end of the hose is connected to a goofy little 3" long encased fan module and thermostat mounted behind the ashtray that sucks air in through the dash vent and that hose. That silly little fan runs anytime the ignition is turned on in my car, you hear it. I removed that hose and plastic vent and installed a switch in place of it to turn on WMI. The fan is still there doing it's thing because the autoheat still works.
Before they decided this autoheat would be a luxury for some people Porsche had a really nice simple and elegant way to control cabin heat with the mechanical lever(s) on the side of the emergency brake handle operating the heat exchanger diverter valves.
Alot of people remove the flaky plastic autoheat box when it stops working and backdate to the old emergency brake handle with smooth working heat lever system that is a pleasure to use and looks better than the autoheat box.
GJF 08-25-2012 06:53 AM
[QUOTE)
Is it the 1980's miami vice style slotted air vent in front of the rear wheels[/QUOTE]
Hey Hey Hey!!!!!! Don't be jealous of our slotted vents!!!!!! Girly man! :)
JFairman 08-25-2012 09:50 AM
Originally Posted by GJF (Post 6934220)
[QUOTE)
I think you're just kidding but those vents do not have a hose on the end that feeds cool air to the center of the rear brake rotors so they are doing nothing and are only there for styling looks.
If you can fit an AC condensor in behind that vent it could make a nice cool air supply for it.
mreid 08-25-2012 09:54 AM
Thank you for the excellent documentation, pictures, and details! It's what makes these forums so valuable.
I also have a 1986 930 that is in need of an a/c upgrade and this will make it much easier. Now, let's talk about the shifter...
Tt surgeon 08-25-2012 10:56 AM
Here is the vent (what I called a sensor, but was corrected). This is where the rubber hose attaches to answer your question.
btw, the vents on a (factory)slant are very functional and also house an oil cooler on the pass side, so they don't exactly 'do nothing', see a pic in the slant thread. Yes, the oil cooler creates a problem. Sorry to divert your AC thread.
The 80s rule!!
http://forums.pelicanparts.com/uploa...1345920868.jpg
GJF 08-25-2012 03:59 PM
Just kidding JFairman,
Mine actually has the ducting to the rear brakes since its not a real slant nose. Actually my ducts are closer to an RSR. But I agree with you they don't do anything for the rear brakes on a factory slant
zcoker 08-26-2012 04:58 AM
Mine are the same with the inner ducts pointed at the rear rotors, keeping things nice and cool back there. I did not know that some slants came without the inner ducting.
GJF 08-26-2012 11:05 AM
Didn't some slants come with the oil cooler in the rear vent? I know they are more for looks than function but I did see a car that was suppose to be a 505 car and had the oil cooler in the right vent. Was that a factory install?
Tt surgeon 08-26-2012 02:44 PM
Yes, factory 505 cars had oil coolers in the pass side vent.
I put up a pic in the slant thread.
Because of the oil cooler, I couldn't do this AC mod.
perhaps this discussion should be moved to that thread?
JFairman 08-26-2012 04:30 PM
"Because of the oil cooler, I couldn't do this AC mod."
I guess you havn't noticed that both the Griffiths and the Zim's fender well AC condensor and fan kits both go in the driver side fender wells. They don't go near the passenger side of the car so you can install them in a slantnose.
Makes sense if you want to increase condensor area on a slant to get colder AC because it's probably impossible to make mounting brackets and fit a 964/993 front condensor and fan into a slant nose left front fender well.
That can be done on a 930 or 911 for real cold AC if you remove the big washer tank.
Tt surgeon 08-26-2012 06:10 PM
Mine has a duct on the drivers side, very tight fit, I still don't think it would fit without modification, (which I wouldn't do on a factory 505). You are correct, there is absolutely no room up front.
gsxrken 08-29-2012 08:02 AM
Thanks- I found it and reinstalled it on the dashboard fitting.
Yesterday I drove up to Griff's again and left him the car while I played 18 at NJ's Ballyowen with a good friend who lives up near there. Ballyowen Golf Club - Northern New Jersey Golf Courses & NJ Country Clubs, Sussex County Golf Course
Hard to beat an hour drive in the 930, a fine round of links golf, and then picking up the 930 for the ride home with magically operational AC!
It wasn't an incredibly hot day for late August, but it was hot enough to get a good fill.
Griff's notes:
83F
42 oz R134a
5.5 oz ester
190 high
23 low
fan speed 2 driving 31.8F (thermostat turned off compressor)
I don't have a dashboard temp sensor to show off with, but it's telling that I had to turn the fan down from high position, and then the thermostat down from full cold to around 5:00 on the dial. And this is someone who can really tolerate AC... when I'm comfortable, most folks tell me it's freezing in this car/house/office.
As I said in the beginning of the thread, I wanted to go straight to nukes with this one; and with three new fans on three new serpentine condensers, new compressor and new lines, new style evaporator, valve and thermostat, I have accomplished that. I doubt I'll have to revisit the AC in my stewardship. I am very pleased with the Porsche-quality components, post-sale support, and of course the outcome. I guess it's been 10 years of associating this car with at-times stifling cabin temperatures, because it was oddly like driving someone else's car on the way home, windows up and AC cranking! Should have done it years ago, and if you're on the fence, learn from me.
Griffiths supplies a range of air conditioning components for your Porsche 911,911s,911t,911 turbo, and 930, such as: Porsche air conditioning upgrades, Porsche air conditioning improvements and updates: Porsche barrier hoses and hose sets, Porsche c
PS- I mentioned this thread to Griff and he may weigh in on the slant-fitment discussion.
Richard930 08-29-2012 12:01 PM
Great write up, I'm feeling inspired enough to maybe have a go at doing this next spring. Summers seem to be getting hotter each year so having some AC is starting to sound pretty attractive!
1986 930 08-30-2012 01:50 AM
Awesome write up!
I have looked at my slant nose and I do not think there is room for the extra condenser there aft of the brake vents. It is a natural place for forcing air into a condenser though. Instead, I thought about putting one in the left front fender in front of the left front wheel if I were to to the "duel khuel" setup. There is no heat soak going on up there either. It could be a better spot than a rear mounted condenser from a thermodynamics perspective.
Looking in the front trunk, I also have the fan for the front condenser mounted beneath the car. It looks like a stock set up. It does not appear that the slant nose pop up light mechanism interferes with it either.
Your write up has inspired me to get on this project this winter. It does look straight forward as far as installing it goes.
Thanks for the post.
Tt surgeon 08-30-2012 05:56 AM
I think the pass side front might be an option w the cannister in the drivers side fenderwell.
M5guy 08-30-2012 07:14 AM
Can you tell me what this part does? On my 86 this round slot was open and I covered it with a flat plug because I could not find anyone who could tell me what is was for. Also, anyone know where can I buy this part?
kuehl 08-31-2012 07:48 AM
The slotted circular device is the cockpit temperature sensor which runs in conjunction with vehicles having automated heat control; does not affect a/c (not found on all models, started around 1984; on 84-85 models the sensor is in the headliner between the sun visors and 86 onward its to the left of the center dash fresh air and heat direction controls).
kuehl 08-31-2012 07:55 AM
We have several clients with slant noses that have mounted the Duehl Kuehl
in front of the LH rear tire, they simply trimmed back the air intake plenum; since the air intake plenum does nothing for brake cooling might as well have a cool driver.
........ a rear mounted condenser from a thermodynamics perspective.
Heat is not an issue with a fender condenser next to a cat or waste gate, its been proven over the past 12+ years.
