930 Intercooler install question
Hi guys...Im installing a longneck intercooler on an 83 930. The stock IC has two outlets/hoses on the Rt. side that attach to the.... Im assuming aux. air valve. One of the hoses has some sort of electical valve or sensor too. The new IC only has one outlet on that side. The pics I have seen show the just the larger hose being used. What should I do with the other one with the electrical sensor on it? Thanks in advance for any help with this!!
The only sensor on my intercooler is overboost sensor connected underneath next to the the boost gauge sending unit. Usualy that second outlet on the right side of the stock intercooler is capped. Maybe you have something added. Can you take a picture of it?
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
I tried to post one. Ill try again tomorrow
I've gone native
Does this help?
'07 997.1tt Blk/blk 600hp, bad to the bone |
I posted this same question a couple of months ago, it's some kind of circuit related to the a/c. It increases the airflow when the a/c is engaged. At least that is my understanding, i just plugged it.
B&B intercooler install
Doug Houston, Texas 997 TT 550RUF '86 930 Last edited by TT Gasman; 09-10-2012 at 09:34 PM.. |
FWIW, there is a 78-930 OEM IC with connection points.
![]() There are few related threads on the forum; both hoses are emission control related and you could plug them both with minor adjustment |
