speednme1's Avatar
BOV/DV question on Ruf intercooler
Hey folks,
I was fiddling with my car the other day and noticed that the factory bov/dv has been removed(probably by previous owner).
My question is can I just add the 964 turbo elbow with a bov(Synchronic DV001x) and connect the output of the bov to this location on the Ruf intercooler(connects to the throttle body)
thanks
Old 10-19-2012, 10:51 AM
speednme1's Avatar
by the way on that old school fuel injector, it's only purpose at the moment is as a plug.
Old 10-19-2012, 12:58 PM
oilonly's Avatar
I would think you could do it there, someone else better confirm though.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 10-19-2012, 06:51 PM
aerodyn930's Avatar
Hello, yes the 965 elbow will work but the source for the recirculating valve needs to connected before the throttle plate, I believe the Ruf I/C did not have a provision for this, Post more photos of your intercooler and the connection to the throttle body and we can suggest a solution , BTW it is not clear in your photos if that additional injector is mounted in a location that would satisfy the previously mentioned criteria,
Regards, lou
Old 10-19-2012, 07:21 PM
speednme1's Avatar
^^^^I will have to remove it from the car or find a similiar photo.
Old 10-19-2012, 07:56 PM
speednme1's Avatar
Regards, lou
Ok here is a photo I found. My location is similiar to the location of the red cap on this pic( I apologize for using someone elses pic)
Old 10-19-2012, 08:05 PM
aerodyn930's Avatar
Yes that would be a correct location , Finding a thread on nipple of the ideal size may be difficult, Maybe welding a nipple to the I/C can provide a solution, Possibly a elbow so that the hose coming from the recirc. valve does not have to make a very tight bend,
Hope this helps ,, lou
Old 10-19-2012, 08:26 PM
speednme1's Avatar
Yes it does..thank you very much.
Old 10-20-2012, 01:17 AM
