No fuel leaks :)
Set fuel pressure to 2.5bar (36psi) as per the bitz install guide ok. Exposed some of the MicroSquirt harness so I could find the purple/black wire (no.15) that when grounded allows the ECU to do a firmware update. Did the update ok :) and installed the latest INI file into TurnerStudio as required. All easy to do following the set by set guide here : V3 MicroSquirt® Controller Code Now I have a blank but up to date ECU ready for setting up http://forums.pelicanparts.com/uploa...1454847016.jpg |
Next step is getting the FrankenCIS harness and new blank harness side by side with the MicroSquirt wiring diagram and moving all the required sensors across plus working out where the additional EFI specific bits connect.
This is the bit I'm least looking forward to :( |
Looking good Gavin. The spaghetti of wires isn't as bad as it looks.
Wiring done........I think :rolleyes:
I basically cut the FrankenCIS sensors off and soldered them to the same wires on the new harness. I also checked on the MS v3 wiring diagram as I did each one to see what it was for and labeled as. I did not bother with the TPS as I won't be using it. There appear to be 3 other FrankenCIS bits that I won't need to connect (see image). One is the power to the old WUR power connection (wires into the back of the FraneknCIS injector, looks like its used to power the injector from the original WUR power) Second is the FrankenCIS injector (wires into one of the Injector pins on the MS harness) And third I'n not sure what it does but it wires to Ground, TPS & SpareInput1. Does anyone know what its for and if I need it? So basically the new harness mirrors the old one. I have left all the so far none used cables on just in case I need them later. Original FrankenCIS harness (what's left of it) : http://forums.pelicanparts.com/uploa...1455459896.jpg New Harness : http://forums.pelicanparts.com/uploa...1455459966.jpg |
There is also a single Purple wire that will go to the old CIS air flow meter connector which controls the fuel pump relay. Forgot to get that in the photo.
I also need to connect the EFI injector harness.
I'll connect the Red wire to the switched positive on the small rear fuse box on the car with a 20A fuse in line as per Bitzracing manual. And I take it the white wires to to pin out no.9 and no.10 on the MS ECU, but is there any particular way round or is it any white wire to either pin out? http://forums.pelicanparts.com/uploa...1455460687.jpg |
Just had a thought on what the unknown FrankenCIS sensor is and I think it maybe something like a control pressure sensor!
Otherwise I don't know how it would of measured that. |
Thanks. I've just wired them up any white cable to either injector out pins now.
One thing I will need to do is change the setting for the fuel pump in MicroSquirt.
As Tony states in the Blitzracing manual " The logic is such that when the pink wire is GROUNDED the fuel pump stops. When the pink wire is un-connected (or HIGH IMPEDANCE), the fuel pump runs. The standard MegaSquirt software expects the fuel pump to operate opposite to this. No worry, the ECU software supplied from BitzRacing has been modified to operate with Porsche fuel pump wiring." So I need to somehow make this same change in the MicroSquirt via TunerStudio. |
I had the same issue with the fuel pump. Some have just added a relay to solve the problem. It's mentioned on one of the MS threads somewhere on here.
OK cool, I'll have a look see.
Just found this post and PM'ed Jimmy2, hopefully he can still make one up :
http://forums.pelicanparts.com/porsche-911-technical-forum/870458-fuel-pump-relay-logic-reversal-megasquirt.html |
After a lot of search's and reading this seems to make the most sense, sort of :
Correct, the default (solenoid unpowered) FP relay current path is from 30 through terminal 87a which is powered during "run/start" on the ignition switch. When the CIS air-plate is at rest (meaning no airflow through the engine) it closes an electrical contact and provides a ground to complete the terminal 85 to 86 current path and activates the solenoid on the fuel pump relay which pulls the switch to terminals 30 through 87 which is only powered during start. This disables the fuel pump under all other conditions except "start". MS is designed to turn on a fuel pump by providing a ground path to activate the FP relay solenoid (85 to 86) and switch 87 to 30 to provide power to the FP during "run/start". 87a is unpowered on the MS wiring diagram (therefore inactive). To use MS to control the 911 fuel pump circuit requires inverting either MS or the OEM circuit. This can be done by making MS turn on the pump by turning off the ground path (inverting the "logic" or possibly modifying the circuit board) or switching the wires to terminal 87 and 87a at the OEM FP relay. These are the red (87a) and yellow (87). I plan to do just that. I will also remove the RPM switch from the circuit. So to cut this short it looks like if I was to reverse terminal 87 and 87a that should do the trick? Effectively I could remove the FP relay find the wires that go to terminal 87 and 87a, cut the wires, swap them over and re-solder them. Is that correct? |
Retro Cars this month with my car on the front and a 6 page spread :)
http://forums.pelicanparts.com/uploa...1456512635.jpg |
Cool. I'll pick up an issue when it lands stateside.
The injector harness has 2-12V and 2-gnd wires. The gnd should be connected to Bank 1 and Bank 2 injectors on Pin 9 and 10 of the ECU connector.
There are a few ways to wire up batch fire injectors. The easiest is that 1-2-3 and 4-5-6 represent bank 1 and bank 2. This works OK depending on your fuel settings. I prefer to wire Bank 1 to 1-6-2 and Bank 2 to 4-3-5. This allows you to have alternate bank firing w.r.t. crank rotations 1 and 2. This can help smooth idle with big cams or big injectors. The effect will be final tune and idle injector pulsewidth dependent. What you end up choosing depends on your wiring preference. One off idle, the injectors will be spraying so much fuel you will not notice any difference in injector wiring. Nice job on the magazine cover. |
Thanks for the info jpnovak. I have now wired up the injectors.
Fuel injector rails have now been tweaked and are a better fit. Most of the MS harness has now been installed back in the car. All boost tubing is back in place, just the intercooler with air temp sensor to fit back. Will start to program the MS now.... |
Had a quick look at the TunerStudio last night and compared it with the screen shots I took of the FrankenCIS TunerStudio setup.
Unfortunately the menu's seem to be changed enough after the MicroSquirt firmware update that I may have a struggle to program everything. One thing I noticed is the MicroSquirt firmware update I did was from this site V3 MicroSquirt® Controller Code and it is for version V3.380a but Steve, that I believe made the FrankenCIS say's that version 3.4 is the latest and FrankenCIS is based on version 3.3.2 I have also today found another site showing v3.4.1 as the latest! Megasquirt Downloads Firmware and Software - Megasquirt EFI So I will try the 3.4.1 firmware at the weekend and see if that has the same menu layout and feature layout as the original FrankenCIS (based v3.3.2). If so I can get on with inputting the settings. |
| All times are GMT -8. The time now is 07:43 AM. |
