EFI is always an option, although you are almost over the line there with CIS....
4. Mercedes v8 fuel head, a little bit of mucking around with the plumbing due to the fuel feeds being in slightly different locations to yours 0 438 100 088 is still WUR based but being a US model also has the lambda adjustment circuit which can be defeated to full max or controlled via FrankenCIS 0 438 101 018 or 0 438 101 016 is the CIS-E unit I have on my 928 and I'll happily send you a DPR interface via Dkubus if you decide to go this way both are cheaply available on eBay for around 200 USD and I'm sure equivalent euro units are fairly common in the UK |
Hi Steve,
Top one is off a Euro Mercedes 380 / 500. Any of these two any good? eBay : |
from the Bosch documentation 111 is fitted to the 5.0 litre motor, so definitely worth experimenting, plus alloy adjustable over your existing cast iron unit
http://forums.pelicanparts.com/uploa...1449279394.png |
Thanks Steve, part is on its way to me.
The SC FD has its fuel feed, return and WUR connections on the back, a right PITA to get to! The Merc FD has its connections on the front so I'll have to extend the fuel lines to fit them. Also by the looks of the position of the Merc connections I may to have to irreversibly cut into the plastic air box to be able to fit it, not sure yet :( Current 0 438 100 031 FD install: http://forums.pelicanparts.com/uploa...1449328295.jpg This is a Merc 0 438 100 111 FD install : http://forums.pelicanparts.com/uploa...1449328661.jpg At the moment I'm thinking the injector fuel lines should still reach OK and hoping the banjo fittings are threads are of the same size as used on the Merc FD :confused: Then I need to work out which is fuel feed, return, WUR on both FD's etc Look's like I may have to cut out this section and then have to sort something out with the air filter etc : http://forums.pelicanparts.com/uploa...1449328978.jpg |
Looking at the images of both FD's installed I'm starting to think it will not work.
The Merc FD I'm assuming is physically bigger than the SC FD due to it having 8 instead for 6 fuel lines. My SC FD is already really close to the air flow intake bonnet, so if the body of the Merc FD is much more than a say 5mm wider on that side it may not fit... |
main body of the v8 units I have here is ~108mm across from flat to flat
Measured the SC FD tonight at 95mm across.
Due to it being such a tight close fit anyway I don't think an FD of 108mm will work, even if it did mount on it would be just about, if not touching the air flow intake bonnet and it will defiantly block access to the 3mm idle mixture screw! The Merc FD should be here tomorrow so I'll measure that and post the results. |
blocking the adjustment screw is probably not a big issue as FrankenCIS has the mixture control as long as the basics are within spec.
from what I can see from the mounting bolt pattern, the mercedes unit - if it fits - should be oriented with the fuel feed/return connections on the same back side as your current unit so the airbox shouldn't need to be modified. http://forums.pelicanparts.com/uploa...1283429241.jpg An alternative option might be to try a Mercedes 6 cyl CIS-E head. 0438101012 better control than WUR based from both precision and range perspectives, but more work as a suitable updraft air plate housing would need to be found as well. |
After some consideration and sleepless nights I've decided to keep the original CIS intake runners and cut the air box down to install a Bitz Racing EFI kit, or at least half of one, I'll use the MicroSquirt ECU and sensors.
EFI thread here : http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/894346-efi-carrera-intake-turbo-3-0-sc.html |
I have ordered these injectors :
ACC-150136 They are exactly the same as the injectors Bitzracing recommend apart from they are 36lbs instead of 30lbs so should do the job and be an easy setup. I also ordered the part EFI kit today and amazingly Tony posted it today (Christmas Eve) you don't get much better than that, thanks Tony :D I cut the air box down today, very quick and easy to do, I'll post pics asap. I will temporarily use the plastic air box and see how it goes. |
Cut down air box (with ally plate stuck in place to cover the pop off hole) :
http://forums.pelicanparts.com/uploa...1451831977.jpg http://forums.pelicanparts.com/uploa...1451831999.jpg http://forums.pelicanparts.com/uploa...1451832021.jpg Seeing as the Cold Start Injector is not required I made a small ally plate and stuck/screwed it back on : http://forums.pelicanparts.com/uploa...1451832085.jpg |
Injector's have arrived from Summit and Bitzracing partial kit should be here in a day or two.
Gavin, I like what you are doing.
Question: instead of simply sealing the old pop-off valve, wouldn't it be a good idea to install a bov in this location with a signal from the very same place. This should serve as a very responsive bov as well as a "plenum-saver"? |
Didn't think of that, can a BOV be mounted after the throttle body? I've only seen then pre throttle body before.
Now that popoff plate is in there I've got no chance of getting it out with all that Epoxy glue... It would of been nice to open the air box and remove the cold start injection divider thingy. Without it I think airflow in the plenum would be much better. But the plastic box is temporary until I get a metal one to replace it. |
You are right about positioning before the TB
Bitzracing kit and injectors all turned up in the new year.
I have cleaned all the intake runners and removed the CIS injector sleeves then installed the EFI injector sleeves : http://forums.pelicanparts.com/uploa...1452960317.jpg Also installed a new crankcase to oil tank hose as the original was looking bad : http://forums.pelicanparts.com/uploa...1452960409.jpg I am just waiting now on some 18mm vacuum line and an 18mm air filter for the AAR before I put the intake runners and cut down air box back on. I want to get everything connected the rear of the air box that needs to be there before getting it in place, otherwise I will be a PITA to get to the back of it when its installed. Fuel rails are also made up and read to go on as and when. |
Progressed a bit more today.
I have now got the intake back on and both injector rails installed plus the AAR connected back up and in place. Intake before install : http://forums.pelicanparts.com/uploa...1454170324.jpg Vacuum ports on rear of TB : Top is going to the AAR (above throttle plate) Small one just below is going to dizzy (as per factory spec) Small one on the right will split to fuel regulator and Microsquirt MAP. Bottom one is back from the AAR (as per factory spec) http://forums.pelicanparts.com/uploa...1454170362.jpg Intake back in place : http://forums.pelicanparts.com/uploa...1454170639.jpg Just before rail install : http://forums.pelicanparts.com/uploa...1454170596.jpg Fuel rail fully fitted : http://forums.pelicanparts.com/uploa...1454170697.jpg Still lots to do but won't get chance until next weekend now. Didn't get any shot of the AAR back on but will do next week. |
Looks good.
Nice to see that you are using good quality hose clamps. |
Finished off the fuel plumbing today, just need to test it for leaks tomorrow.
http://forums.pelicanparts.com/uploa...1454771736.jpg http://forums.pelicanparts.com/uploa...1454771785.jpg |
I've taken screen shots of every settings page in the TunerStudio program as a reference.
I now need to update the firmware for the MicroSquirt which will in turn reset all the settings and remove any specific FrankenCIS bits. Then I will be onto the harness. I have a new harness ready to go. My plan is to carefully strip down the original harness and then move across the required sensors to the new harness installing them on the same cables they where on. Then I need to install the the extra sensors etc that need to be there for the EFI side, like the engine temp, fuel pump cut off and injectors harness. At that sage I need to get all the MicroSquirt setting back in and adjected for EFI plus additional settings for EFI. |
| All times are GMT -8. The time now is 10:31 AM. |
