Floating rotor install
I bought a new set of floating rotor for myn78 930. I need to replace te old ones. Does anyone have the instructions swapping tha hats out? I would imagine it should e straight forward but I don't have the torque values. Should I install new hardware (bolts) or should they be fine on a street car?
Thank you in advance?
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Smart quod bastardus
Are you replacing rotors only or the hats too?
If rotors only, then just pay attention to the order in which the nuts and mounting hardware come off the old rotor and replace in reverse order. I think the hat has a chamfer on one side of the outer edge that has to be positioned correctly in order to allow the rotor to float when torqued down, otherwise the hat could be installed backwards to the rotor. I am not 100% sure on this as its been a few years since I replaced mine and I put everything back together in reverse of how it came off.....using the assumption that the previous mechanic knew what he was doing and had assembled it right before I got there. Those are small 4mm nuts I think so torque to snug using a 1/4 inch socket and don't overtighten them. I think they use lock washers to prevent losening. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
My floating rotors use a bent tab set up to retain the nuts - stock part from Porsche. May be a bit of overkill, but I suspect that losing a few of the itty bitty bolts would be a bad thing if you braked firmly.
They make a lot of noise though....even though I put a dab of high temperature silicone on the sliding portion to provide a bit of a noise absorber. Dennis |
beancounter
Some info in my thread on the topic about how to orient the ring when you assemble the rotors so that they float correctly:
'79 930 - Brake refresh in progress
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Jacob,
Thanks for the link. I have read that thread a couple of times in the past. I added to it the torque values for the floating rotors to be 10 Nm or 7.36 ft #'s per the manual I have section 46-8. John
