Banned
well - overboost switch
I unintentionally tested my overboost switch a couple of days ago. I changed the voltage regulator, taking off the Garretson intercooler like I have done countless times over the years, and like some kind of mega moron, neglected to connect the wastegate hose before taking the 930 for a test drive - it quickly overboosted in 2nd gear and I got the "face in the wind shield" experience. Nothing seems to be damaged - runs perfectly, pulls hard, no smoke, etc. (drove it hard for about two hours today) - but who knows. I guess if I am paranoid enough about broken rings I could do a leak down test (but would rather not). I used Racewear studs and rod bolts when I rebuilt the engine several years ago . . . What do you guys think?
The good news is that the thing now charges like it is supposed to - ha!
You can bet I won't forget that hose again!
Old 12-24-2012, 05:01 PM
I don't think that would have hurt it at all.
I think broken rings happen when someone holds it at too high boost for the timing and fuel being used and detonation is intense and continuous for 2 or 3 seconds or longer at a time.
Old 12-24-2012, 05:11 PM
Banned
Coming from you, that is music to my ears (eyes)!
Old 12-24-2012, 05:29 PM
Makes sense. What would be the point of the over boost switch if, when it kicks in, you're already screwed? No boost signal hose AND a grounded over boost switch = Rebuilding Forum.
Ken
1986 930 2016 R1200RS
Old 12-24-2012, 07:06 PM
DSPTurtle's Avatar
That's why the switch is there. Count your lucky stars and drive that beast.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 12-24-2012, 07:29 PM
