twin scroll
I'm starting one of my winter projects, and thought I'd throw this out there. What are you guys using for a gasket between the header flange T-3 and turbo? I see Cummings has a copper gasket with divider in the center. Is there any other types? Philip http://forums.pelicanparts.com/uploa...1356308078.jpg
We use the OEM metal gaskets. They are pricy but good quality.
Brian
Is there a OEM gasket with a divider in the center to divide the 2 secondary pipes? I cant find a listing. Philip
some progress
Just have to fab the discharge pipes for the waste-gates.:D How easy is it to bend 16 g stainless ?http://forums.pelicanparts.com/uploa...1360707544.jpg
http://forums.pelicanparts.com/uploa...1360707589.jpg http://forums.pelicanparts.com/uploa...1360707615.jpg |
Philip,
Nice job on the mod. For bending, if you have a fab shop near with proper tube bending equipment its easy, otherwise you could pick up elbows and fit them in and weld. |
Yea, it might be just as easy to miter and weld the offsets needed.
progress
Looks like I may put the rear bumper valance back on to cover some of the bling! What are you guys using for the vacuum/pressure lines to the waste-gates? Philiphttp://forums.pelicanparts.com/uploa...1362246448.jpg
http://forums.pelicanparts.com/uploa...1362246471.jpg |
For the vac/pressure line I used Parker hi temp hydraulic hose.
plain old fuel line and hose clamps works fine for a street car.
| All times are GMT -8. The time now is 11:48 PM. |
