twin scroll
I'm starting one of my winter projects, and thought I'd throw this out there. What are you guys using for a gasket between the header flange T-3 and turbo? I see Cummings has a copper gasket with divider in the center. Is there any other types? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Crotchety Old Bastard
We use the OEM metal gaskets. They are pricy but good quality.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Brian
Is there a OEM gasket with a divider in the center to divide the 2 secondary pipes? I cant find a listing. Philip
some progress
Just have to fab the discharge pipes for the waste-gates.
How easy is it to bend 16 g stainless ?![]() ![]()
Philip,
Nice job on the mod. For bending, if you have a fab shop near with proper tube bending equipment its easy, otherwise you could pick up elbows and fit them in and weld.
87 930, |
Yea, it might be just as easy to miter and weld the offsets needed.
progress
Looks like I may put the rear bumper valance back on to cover some of the bling! What are you guys using for the vacuum/pressure lines to the waste-gates? Philip
For the vac/pressure line I used Parker hi temp hydraulic hose.
87 930, |
plain old fuel line and hose clamps works fine for a street car.
Chain fence eating turbo
