Preferred pronoun:Maestro
Norm K's Avatar
Were Broken Head Studs ...
... common to the 930 or is this limited more to the 911?
I've seen conflicting information (imagine that, conflicting info on an automotive forum!) as to whether it's as common in 930s as in 911s, if it's largely limited to earlier cars (and even then to those with magnesium cases), if it's a Divlar thing, etc...
I suspect this has been hashed out here many times but a search for some sort of definitive answer, should one exist, certainly doesn't pop right up.
Norm
Old 12-28-2012, 12:38 PM
I had one broken on my 81 930....Mag case.
From what I've read it's common with early Divilar application, whether it's a 911 or 930, from the late 70's early 80's up until the 993 application when the studs were then coated to prevent the corrosion at the base of the case.
Someone may chime in with more knowledge than this, as this is my personal experience.
When the common bond is a Porsche, the people who own them are even more interesting than their cars.
Old 12-28-2012, 01:07 PM
Brando
quattrorunner's Avatar
I bought an engine that was torn apart because of broken head studs. 77 930 3.0
Turbo powa!
1977 911s. it's cool
Old 12-28-2012, 01:50 PM
Your 81 has a mag case I thought for sure they were aluminum cases.
Old 12-28-2012, 02:24 PM
That's what I thought, but the machinist told me that the case was Magnesium. He may have been wrong however. Considering he doesnt deal with Porsches on a regular basis. He had the case to take care of the remaining piece of stud in the case.
We found out the hard way that these studs cannot be drilled successfully. He removed the stud with an EDM machine... It's been a very expensive process from there...
Old 12-28-2012, 02:30 PM
They are aluminum.
Old 12-28-2012, 02:34 PM
Originally Posted by JFairman View Post
They are aluminum.
Meaning that all 930's were aluminum?
Old 12-28-2012, 02:36 PM
All the 3.0 liter and bigger engines are aluminum.
A friend has a '77S and it's the last of the magnesium cases. Those usually or maybe always need to be line bored when rebuilt.. expensive.
The SC replaced the '77S in '78 and it had the aluminum 3.0
Old 12-28-2012, 03:28 PM
jsveb's Avatar
The carrera 3.0 ( 930/02 )
Was also made out of alu. It is identical to the early turbos.
My 76 Carrera does have a mag tranny case though.
Old 12-28-2012, 05:13 PM
newbie
timspu's Avatar
My 1988 Euro engine had a sheared head bolt. Engine was popping under boost only.
Very expensive repair. Had all replaced whilst engine was stripped. Also needed new valve guides. Motor had done 80K miles on it.
Old 12-29-2012, 08:10 AM
