Heat Exchangers for 965 3.3
Hi All,
Need some help here... Would the 930 factory heat exchangers (along with the crossover and turbo mount pipes) directly bolt on to the 965 3.3? Part numbers for the heat exchangers appear slightly different: 1. 965 3.3 Heat Exchangers (930 211 033 02) vs 930 Heat Exchangers (930 211 033 01) 2. 965 Exhaust Line (Crossover Pipe) (930 111 169 05) vs 930 Heat Exchanger Exhaust Line (930 111 169 05) - same part number. 3. 965 Exhaust Line (Turbo Mount Pipe) (930 111 003 06) vs 930 Exhaust Line (930 111 003 04) Thanks in advance! |
Crotchety Old Bastard
Not unless you also use the 3LDZ turbo or modify the bracket. There are subtle other differences as well but not major enough to prevent installation. The 930 J-pipe also has no mount for the waste gate catalytic converter / heat pipes.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 02-08-2013 at 08:42 PM.. |
Thanks for the info! Appreciate it!
