Part name?
Just looking for leak spots, does this and what is it called?
Please ignore the purple writing.... i stole the photo. http://forums.pelicanparts.com/uploa...1360551055.jpg |
oil thermostat. Sealing o-ring known to go bad and leaks.
Wow nice clean engine.
Is it possible to get off with the motor still in?
It is easier on the 930. I did it but I don't have much in the way ie airbox, emission devices etc. I think you can. If not, a partial drop is possable.
Benny you can do it with the motor in place, you'll have to remove the intercooler, air cleaner housing, and possibly, the air metering unit/fuel lines, but not the intake manifold like pictured below. Clean around the thermostat very well so none of the grime can fall into the opening after you pull it out.
I think you'll need to remove the oil press light sender and banjo bolt so you can get the turbo oil feed line out of the way so you can pull the T-stat up. Other items to inspect for leaking are the oil light pressure sender, breather hose connection, and the breather cover gasket. http://forums.pelicanparts.com/uploa...1360635488.jpg http://forums.pelicanparts.com/uploa...1360635560.jpg http://forums.pelicanparts.com/uploa...1360635580.jpg |
| All times are GMT -8. The time now is 06:08 PM. |
