89 930.
Benny771's Avatar
Question Part name?
Just looking for leak spots, does this and what is it called?
Please ignore the purple writing.... i stole the photo.
Old 02-10-2013, 06:52 PM
7.0:1 > 11.3:1 > 7.0:1
oil thermostat. Sealing o-ring known to go bad and leaks.
Old 02-10-2013, 07:04 PM
Brando
quattrorunner's Avatar
Wow nice clean engine.
Turbo powa!
1977 911s. it's cool
Old 02-10-2013, 09:11 PM
89 930.
Benny771's Avatar
Is it possible to get off with the motor still in?
Old 02-11-2013, 08:12 AM
Brando
It is easier on the 930. I did it but I don't have much in the way ie airbox, emission devices etc. I think you can. If not, a partial drop is possable.
Turbo powa!
Old 02-11-2013, 11:49 AM
Preferred pronoun:Maestro
Norm K's Avatar
Sure is. It looks exactly nothing like mine ...
When in doubt, use overwhelming force.
Old 02-11-2013, 01:25 PM
Benny you can do it with the motor in place, you'll have to remove the intercooler, air cleaner housing, and possibly, the air metering unit/fuel lines, but not the intake manifold like pictured below. Clean around the thermostat very well so none of the grime can fall into the opening after you pull it out.
I think you'll need to remove the oil press light sender and banjo bolt so you can get the turbo oil feed line out of the way so you can pull the T-stat up.
Other items to inspect for leaking are the oil light pressure sender, breather hose connection, and the breather cover gasket.
Old 02-11-2013, 06:23 PM
