Short Throw Shift kit
Anyone have good experience which is the best to use?
Currently am working on an 81 930 I see Pelican has the choice of OE, Genuine Porsche, Weltmeister. Porsche 911 & Carrera Shift Linkage - Page 3 Have seen a few threads but wanted to see what is working the best ? Thanks for all the help. |
The Wevo is the preferred brand and works fantastic on a good transmission. But if the transmission is tired after 32 years, then no shifter will cure that, might even make things worse.
Another vote for Wevo. Get the coupler too.
It's not a matter of the tranny being shot, just wanted a shorter shift.
With the Wevo , what kind of time am I looking at for install? |
Does anyone have any pictures of their wevo for comparison from the standard, tall or classic.
Thanks |
I only have experience with the weltmeister, PO installed in my car and I'm not real impressed. I will be removing it soon as its pretty sloppy.
Wevo is in a class of it's own. It is the nicest made and best of them all.
That said, the Weltmeister has the shortest throw of all of them and if you replace the inexpensive origonal cup/ball bushing at the bottom where it connects to the long horizontal shift rod in the center tunnel, the horizontal shift rod bushing, and either make your own snug fitting shift coupler bushings out of AC hose like I've done or replace it with the very nicely made Wevo shift coupler it works pretty good and cost around 1/6 the price of the Wevo. My Weltmeister has short throws, it's tight and is not sloppy at all. I like it. Another thing I like about using the Weltmeister in my experience is it uses the origonal angled back steel shift rod the shift knob is on. I didn't like having to lean forward a tad to reach 3rd gear so I removed the leather shift boot, put a damp towel over the seats to protect them, and used an acetylene and oxygen torch to heat the vertical shift rod red hot where it makes the bend back toward the driver. Then while in second gear I pulled the shift knob back towards me and a little to the left where it is more comfortable for me and doesn't come too close to the driver seat. Now 3rd gear is not as far away with no lean forward to select it and shifting through all the gears is much more comfortable and pleasent for me. In the end the Wevo is made alot better than any other I've seen but you can't change the shape or angle of the one with the aluminum vertical shift rod. The Weltmeister is simpler, has shorter throws than any other shifter that mounts in the origonal position that I know of, and cost alot less. |
http://forums.pelicanparts.com/porsche-911-technical-forum/679598-show-me-your-wevo-shifter-installs.html |
http://forums.pelicanparts.com/uploa...1361129879.jpg |
Whats the gold thing in front of the shifter?
935 boost knob. Some call it "dial-a-death".
That's the only gold anodized one I've ever seen. They're usually satin aluminum color or clear anodized. You're so lucky to have an original one.
I've seen people offer a thousand bucks or more for one of those... Looks really good the way you installed it. Was it like that when you found it under your seat? |
i'm assuming for a methanol injection system??
If so are you happy with it? Was considering one of those on my list... |
Is there a detailed thread you know about that explains that topic? Did a quick search but was not using the right keyword obviously.
Thanks |
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/376551-how-make-stock-wastegate-adjustable.html |
+1 Correct
Sweet!
I'm glad you got one of those and thats a real nice one. I remember seeing them mounted by the shift knob or where the clock was in some 935's so the driver could take his right hand off the wheel and reach a few inches to turn it up and pass a car or whatever. You've got the coolest shifter and center console in the 930 world and it changed the subject of this thread because it looks so good... excellent clean looking job on the console! |
| All times are GMT -8. The time now is 06:19 AM. |
