Anyone smart on 911 turbo engine numbers?
Greetings!
I recently purchased an '89 911 Turbo Cab and it has an engine number stamp of 68K00243. Can anyone tell me what each of these numbers mean? I know the 6 is for a 6-cylinder, but that is where my knowledge ends. The car 1st entered service in December of 1988. Any help would be greatly appreciated.
Sean
Old 04-29-2012, 07:59 PM
sudo apt-get purge 930
equality72521's Avatar
68K00243 is a K program engine meaning it was produced between 8/88 and 7/89. Engine type is 930/68. It would be a 1989 model.
--clutch-monkey
Old 04-30-2012, 04:34 AM
JJK78-951's Avatar
Very interesting! I'm always looking for more info and while comparing this info to mine came up with a question.
I recently bought a 1979 Euro 930 and my engine # is 6790627. Figuring now 6 = 6 cylinder, 79 = 1979, but the 0627 it ends in i find a bit either odd or coincidental as my VIN # ends in 0626, almost as if it got the next motor on the line?
Is this odd or just coincidence?
THANKS!
J
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 04-30-2012, 10:46 AM
OK, that all checks out. Am I correct in assuming the 00243 is just the engine production sequence number and has no association with my vehicle's VIN (either the U.S. VIN on the A-pillar or the European VIN stamped in the trunk)? Also, does the 8 indicate a production year of 1988?
I have a 60's GM muscle car that is a true numbers matching vehicle which can easily be confirmed because the VIN is actually stamped into the engine block. Does Porsche use such a system, or is the letter "K" as close as I can get at confirming an engine/vehicle match. I have no reason to believe my car ever had an engine swap . . . this is more for curiosity sake now.
Sean
Old 04-30-2012, 12:04 PM
The 8 indicates it is a U.S. turbo engine. The K indicates the production. The 00243 is the production sequence... it was the 243rd engine in the run.
--clutch-monkey
Old 04-30-2012, 12:53 PM
THANKS!
J
It is the way is was for the earlier cars to have matching final numbers. Example, the VIN range for a 1979 Euro turbo was 9309700001-9309700820 with engine numbers 6790001-6790820. It's a little odd that yours is one digit later. Maybe the 626 engine was bad on the assembly line so they grabbed the next one????
--clutch-monkey
Old 04-30-2012, 12:59 PM
JJK78-951's Avatar
Thanks Mark,
Yeah I thought about that but figured they wouldn't do that as it screws up everything after that, but then again all they have to do is note that on the build sheet to verify the "matching numbers". Now to figure out how to get that build sheet??
John~
Old 04-30-2012, 06:20 PM
Interesting thread. To add more info. to the discussion.
I have a 1978 German market car, Vin# 93008700421 my engine is also off by a few digits Engine # 6780428. The numbers match the COA
Old 05-01-2012, 04:59 AM
So, does anyone know the answer to my question? Is there anyway to positively match an engine to a car in a late 80's 911 turbo? In other words, did Porsche stamp the vehicle VIN anywhere on the engine block? Or is the "K" designation in my engine stamp (which defines the production date range) as close as I can get?
Sean
Old 05-01-2012, 05:22 PM
Sean
I have never heard of or seen a VIN stamped on a Porsche engine.
People generally rely on the 'Certificate Of Authenticity' for correct engine, trans. #'s and options for their car. There is debate on their accuracy. I believe a "COA" cost about a $120 now.
Old 05-01-2012, 06:52 PM
GUNNR's Avatar
order a COA..it has the numbers for the engine and trans...
Grandpa is just an antique little boy!
Old 05-02-2012, 10:44 AM
TT Gasman's Avatar
How about 67D0412 ? Thanks!
Doug
Houston, Texas
997 TT 550RUF
'86 930
Old 05-02-2012, 05:01 PM
JJK78-951's Avatar
Ficke,
Do you know how to obtain a COA for a euro car? I checked the website for Porsche North America and the COA there is only available for US cars, not ROW
Thanks!
J
John~
Old 05-02-2012, 07:02 PM
Here is a picture of the COA that came with my European 930.
I have never ordered one. I also got a letter 2002 with this COA from PC North America.
So at least in 2002 you could still get COA for Euro cars from PCNA.
At that time the Phone number was a GA number (770) 290-3500
Good luck, Fritz
Old 05-02-2012, 08:19 PM
Romel
68K00243: 6=six cyl, 8= US - Turbo, K=1989, 243=engine seq # produced.
6780428: 6=six cyl, 7=Turbo (non-US), 8=1978, 428=engine seq # produced
Old 02-28-2013, 04:44 PM
M5guy's Avatar
The engine number on my COA is 12 higher than the car VIN.
Engines do get pulled out of production and sent back to rework, and then sent back to the line to be put in a later car. ( a nightmare scenario for mid year Corvette owners). There is a reasonable chance that 626, or some engine before it, was pulled.
SR
86 930
x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette.
Old 02-28-2013, 05:09 PM
I would be surprised to see an older 930 where the last digits match the chassis number. This whole "matching numbers" thing is quite recent with Porsches. I have owned a few 930s and a ton of 911s and I do not recall ever seeing a match.
It is great to get a COA and confirm "matching numbers", but with Porsches that simply means it has the same engine it started out with ...but don't think that the COA isn't sometimes incorrect.
JR
Old 03-06-2013, 02:41 PM
Just for reference
81 Euro
Body 348
Engine 394
Old 03-08-2013, 04:39 AM
