henrymfisher's Avatar
930 Feels Like It Is Running on Less Than 6 Cylinders
Hi guys,
So I went out for a nice long drive yesterday. Car felt like it was running well.
Stopped for lunch and when I went to restart the car it was running terrible, like it was running on 5 or even 4 cylinders. Since I was ill prepared for major diagnostics on the road I drove home slowly.
I have checked and all cylinders have spark, so it seems like ignition is out (I have a twin plug electromotive ignition with built in redundancy - each coil pack runs 2 separate cylinders)
So now onto fuel. I removed the air cleaner to access to air flow plate on the CIS and I disconnected one of the steel fuel lines to one injector. Actuated the air flow plate to trigger the pumps and very little fuel came out (drops - 1 teaspoon). So the question is do I have a dead fuel pump? Do I have a failing fuel head or WUR?
I own a set of the CIS fuel pressure gauges but need a refresher course on how to use and what to read for cold and warm temps.
The car is a 1976 930 although it has a complete 3.3 intake, CIS, Euro lines, brand new injectors, Brian Lesek WUR.
You can also email me at henrymfisher@comcast.net
Thanks,
Henry
Old 05-28-2013, 08:00 AM
oilonly's Avatar
This is the most straight forward way on how to use your CIS gauge that I have ever found.
CIS test gauge - procedure?
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 05-28-2013, 01:42 PM
