Lowered correctly...finally!
Hey all,
Tried to do this as a last winter project, but life got in the way. As some of you know, I'm running a rather low stance car, so this was long over due. Anyhooo..Just installed 40mm raised front spindles, bump steer kit {with added support bracket} and Von shocks front / rear, with new ball joints for good measure. Shocks and strut modifications and bump steer kit through Elephant Racing {Chuck is great}, very quick turn around on parts, with perfect implementation. Ball joints from our host. Cursory ride to the alignment shop, was very encouraging, way better ride, better bump compliance. The cars front suspension does not seem to be fighting the rear suspension anymore either. Before the car tended to pogo front to rear a bit, and I had a lot of rear patter over pavement seams & such. I will give you all a better update, after I pick up the car from the alignment shop this afternoon. Should be a fun drive home tonight. Suspension particulars: 23/30mm torsion bars, 22mm Tarett frt. & rear sways, Wevo rear sway mounts, strut tower brace, Rebel racing frt. & rear bushing systems, 40mm raised spindles, bump steer kit, Von shocks, 17 x 8.5 frt., 18 x 11 rear Fikse 5s running 255's/295's B.F.G-KDW's Mark |
good info! I am starting down that road now (albeit a little higher, but not much). Starting with Von shocks in rear, as soon as the motor is back in..........well, the rest comes :).
Update,
Did a full 4 wheel alignment & corner balance while I was there at the alignment shop. Between the parts upgrade and the corner balance, that was certainly money very well spent! Car is way more composed, allowing greater confidence to drive much, much faster....just what I needed.....sheezzz. The car simply tracks like it is on rails, no more dancing around. Mark |
How does the steering feel with the raised spindles?
Pictures of the new stance would be nice to compare; in your case it could not be any lower so... |
Wtf, no pics with the new hardware?
Well I guess I'm in the dog house now....
Did not take any pic.'s of installing the parts, I'm sorry. As a matter of fact, I don't think I've ever posted pictures of any modifications that I've done. Some peoples kids........you buy em books & send em to school, and what do you get...sheezzz. I just get down to doing the work as I always do. Non-stop from start to finish, until it's done. In this case took 2 hours to tear the front apart, waited a week for parts to get turned-around, then 4 hours to put the front all back together and a 1/2 hour for the rear shocks. The ride height is exactly the same as before, only now it has the correct geometry to the suspension, as the Doctor designed it. I will try to wash the old girl this weekend, then snap a shot, to quell the angry mob so to speak. *Miguel* The steering feels great, same exquisite road feel & feed back, just no longer twitchy. Far less tug & pull of the wheel when going over rising or falling road crowns & undulations. Mark |
^^^ That's what I thought... I believe that became the top of my list.
Photo update.....http://forums.pelicanparts.com/uploa...1370740165.jpg
nice work
That is beautiful.
Rod |
The perfect stance!
Nice!
Oh yea...thats what I'm talking about...perfect!
Sweet! The stance looks great and I like the reflection of green tree leaves and blue sky and clouds in the hood.
Nice! Love the stance of your car, it's all just right.
what kind of valving do your struts have ? Took my car out for the first track test at Sebring long track (OHHH .. what a ride that was ) and did I have some problems. This beast is all stock with just small adjustments and lots of miles. I just spent the last year putting it together after I bought it as a basket case . So just to drive it was fun to say the least . Lots of work still to do and reading all the posts sure helps to put a great package together . Any info on anti roll bars size and torrsion bar size would help .. Thanks guys for all the help
Thanks guys, and it's really cool when your money spent IS worth the money spent.
Kozmo930, The Von shocks are valved to match the torsion bar sizes, through Elephant Racing. If you look at the bottom of my opening statement for this thread. You will see that I noted all of the particulars & sizes of my suspension set-up. Hope in some way it helps you out with your set up. Mark |
Thanks I will give elephant a call Monday see what I can do ... Nice car by the way it does look good. Must be nice driving the back roads up Mt. Rainier . I lived in Bellevue for many years so the back roads I know are a blast to drive .
Stance Looks Great!!
We need more pictures, Mark! You're such a tease!
How is the rear tire wear and how much camber before and now? Have you tried spacers or is it already close to the wheel well outer edge? I bought some spacers to get mine flush but I havent driven it yet so dont know if it can move freely on bumps. Using jack its ok but streets might do some funny things on high speed corners with bumps.
Hey Smurfbus,
I'm running 2.5 degrees neg. rear camber. My car is my daily driver, and I put about 10-12K per year on it. Get 1 year for a set of rear tires, and about 1 1/2 years out of fronts. I actually change out the fronts not because of wear , but after about 15-20K the tires have gone through too many heat cycles and are hard as rocks. There is no room for rear spacers with the car this low. Mark |
| All times are GMT -8. The time now is 06:23 PM. |
