Update After Modifications
Okay, after installing headers/exhaust, air intake, inter cooler, new k27/29 turbo, Tial 46mm (1 bar spring), Patrick Motorsports Clutch and LWFW, Leask WUR; keep in mind that this is the first run out of the box, still needs some dialing in; she produced 352 rwhp at 4800 rpm and 436 ft/lbs at 3400rpm. She is a little rich below 3500, at 4000 rpm AFR is 11.44 (ideal) then she starts to lean out to 12.75 AFR at 5000rpm (shut her down after that).
I'll try to post up the dyno sheet later today. I think we need to work on the timing (too much torque?) and add fuel above 4500rpm to keep her under 12 AFR. We also need to dial it down (fuel is at 10 AFR or so) below 3500. I think if we dial it in, we can achieve 375 rwhp/400 ft/lbs. Any thoughts? Motor is a stock '79 3.3, all new hoses, oil cooler, spark plugs, plug wires, etc, etc.
As far as dialing it in for 25 more others here will have to advise.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
More like 135 hp over stock. These cars had 265 fwhp from the factory, now she is close to making 400 fwhp, 350 rwhp. With a little more tuning, she should make close to 420 fwhp, 150 hp over stock.
Dyno
I believe Porsche did use RWHP figures, so the USA 265-280HP depending on the year was RWHP.
Forget the numbers (other than AFR)- how does it drive? I'll bet you've transformed the car with all the right mods.
Ken 1986 930 2016 R1200RS |
Interior shot
That Fabspeed is some good looking stuff you have there.
63 356 So Called Outlaw 76 930 |
Got it. Keep thinking to myself that these are near 300 fwhp engines when stock. Nice set up.
Ingenieur
Porsche has never used rear wheel horsepower for rating engine power output. It is flywheel power and is measured in PS, then converted to HP.
Prrrreeeetttycool!
Impressive torque that early... was the dyno properly calibrated? If so, congrats! |
Brando
How's it sound?
Turbo powa! 1977 911s. it's cool |
Smart quod bastardus
Something was bothering me about the dyno graph.
How come the torque and hp curves dont intersect at 5250rpm point? They should cross at that rpm unless you altered the scales on the graphs somewhere between the two. Not trying to be a ball buster but this is confusing and just wanted clarification. Those are impressive numbers for the changes you have listed. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Funny this one doesn't intersect there.
HP = (Torque x RPM) / 5252
At 5252 the TQ and HP values should be equal. In the graphs above, it appears the values are the same at 5,250rpm. It looks wonky because the scaling of the left axis and right axis are different.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
You're right, the values on my graph are both at about 350 at 5250. He might of had it in 4th, would that have an effect on the results?
Ideally, a 1:1 drive ratio. For a 930 4-sp, 3rd is closer to 1:1 than 4th is.
