-   -   Update After Modifications (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/755249-update-after-modifications.html)
9Thirty 06-10-2013 12:16 PM
Okay, after installing headers/exhaust, air intake, inter cooler, new k27/29 turbo, Tial 46mm (1 bar spring), Patrick Motorsports Clutch and LWFW, Leask WUR; keep in mind that this is the first run out of the box, still needs some dialing in; she produced 352 rwhp at 4800 rpm and 436 ft/lbs at 3400rpm. She is a little rich below 3500, at 4000 rpm AFR is 11.44 (ideal) then she starts to lean out to 12.75 AFR at 5000rpm (shut her down after that).
I'll try to post up the dyno sheet later today. I think we need to work on the timing (too much torque?) and add fuel above 4500rpm to keep her under 12 AFR. We also need to dial it down (fuel is at 10 AFR or so) below 3500. I think if we dial it in, we can achieve 375 rwhp/400 ft/lbs. Any thoughts?
Motor is a stock '79 3.3, all new hoses, oil cooler, spark plugs, plug wires, etc, etc.
http://forums.pelicanparts.com/uploa...1370890449.jpg
9Thirty 06-10-2013 12:40 PM
http://forums.pelicanparts.com/uploa...1370892749.jpg
http://forums.pelicanparts.com/uploa...1370893031.jpg
http://forums.pelicanparts.com/uploa...1370893227.jpg
oilonly 06-10-2013 04:23 PM
Any thoughts?
Yes, I like the fact that we can bolt on an extra 60 hp over stock.:D As far as dialing it in for 25 more others here will have to advise.
9Thirty 06-10-2013 04:54 PM
More like 135 hp over stock. These cars had 265 fwhp from the factory, now she is close to making 400 fwhp, 350 rwhp. With a little more tuning, she should make close to 420 fwhp, 150 hp over stock.
9Thirty 06-11-2013 07:54 AM
Dyno
http://forums.pelicanparts.com/uploa...1370962455.jpg
gsxrken 06-11-2013 10:49 AM
I believe Porsche did use RWHP figures, so the USA 265-280HP depending on the year was RWHP.
Forget the numbers (other than AFR)- how does it drive? I'll bet you've transformed the car with all the right mods.
9Thirty 06-11-2013 11:39 AM
I haven't had the chance to drive it yet, still doing some slight work to it that prevents me from driving it. I believe you may be mistaken with the horsepower numbers. Porsche used engine dyno results which are a far cry from wheel horsepower. 265 was the engine dyno number (flywheel) for the U.S. 1979 930. The wheel horsepower was probably closer to 240. So we are really waking this motor up from a coma when we give it the ability to breath with free flowing open exhaust and headers, good fuel delivery, and a larger efficient turbo. The clutch, LWFW and WEVO shifter doesn't hurt either.
Interior shot
http://forums.pelicanparts.com/uploa...1370975951.jpg
Les Paul 06-11-2013 11:45 AM
That Fabspeed is some good looking stuff you have there.
oilonly 06-11-2013 01:06 PM
Got it. Keep thinking to myself that these are near 300 fwhp engines when stock. Nice set up.
Speedy Squirrel 06-11-2013 03:53 PM
Porsche has never used rear wheel horsepower for rating engine power output. It is flywheel power and is measured in PS, then converted to HP.
Miguel Antonett 06-11-2013 06:19 PM
Prrrreeeetttycool!
Impressive torque that early... was the dyno properly calibrated?
If so, congrats!
quattrorunner 06-11-2013 10:16 PM
How's it sound?
9Thirty 06-12-2013 07:08 AM
How's it sound?
Sweet!
9Thirty 06-12-2013 07:10 AM
Prrrreeeetttycool!<br>
<br>
Impressive torque that early... was the dyno properly calibrated?<br>Yes.
<br>
If so, congrats!
Yes.
fredmeister 06-12-2013 02:03 PM
Originally Posted by 9Thirty (Post 7494180)
Yes.
Something was bothering me about the dyno graph.
How come the torque and hp curves dont intersect at 5250rpm point?
They should cross at that rpm unless you altered the scales on the graphs somewhere between the two.
Not trying to be a ball buster but this is confusing and just wanted clarification.
Those are impressive numbers for the changes you have listed.
Fred
9Thirty 06-12-2013 03:03 PM
</div>Something was bothering me about the dyno graph. <br>
<br>
How come the torque and hp curves dont intersect at 5250rpm point?<br>
<br>
They should cross at that rpm unless you altered the scales on the graphs somewhere between the two.<br>
<br>
Not trying to be a ball buster but this is confusing and just wanted clarification.<br>
<br>
Those are impressive numbers for the changes you have listed.<br>
<br>
Fred
Didn't touch the graph as far as I know. I wasn't there, so I'll ask my tuner. Is this an absolute like light speed equations or is there some variation? 4th gear vs 3rd?
9Thirty 06-12-2013 03:13 PM
Funny this one doesn't intersect there.
http://forums.pelicanparts.com/uploa...1371075142.jpg
TurboKraft 06-12-2013 04:19 PM
HP = (Torque x RPM) / 5252
At 5252 the TQ and HP values should be equal.
In the graphs above, it appears the values are the same at 5,250rpm. It looks wonky because the scaling of the left axis and right axis are different.
9Thirty 06-12-2013 05:37 PM
You're right, the values on my graph are both at about 350 at 5250. He might of had it in 4th, would that have an effect on the results?
TurboKraft 06-12-2013 06:04 PM
Ideally, a 1:1 drive ratio. For a 930 4-sp, 3rd is closer to 1:1 than 4th is.
