Hi guys,
I have read a lot of threads here, but now I am in the final step before place the order, but I will really appreciate your help, advice, and suggestions, you can recomend, add or substract any item. Porsche 1987 930 turbo Summer Yellow 1) Turbo: I am looking to improve my Turbo K27 (I dont know exactly what type of K27 do I have, have to check with my Mech), options: a)Aerocharger 930 VVT turbo Kit - b)Rarelyl8 K27/K29 hybrid - c) Turbokraft GarretT G35R 2) Intake: a) Fabspeed Cold Air Intake System, 3) Intercooler: a) Fabspeed Long Neck Intercooler, b) Turbokraft Long Neck Intercooler c) Rarelyl8 Intercooler 4) Wastegate: Dont know If I have to change my Wastegate, Only thing I know is I will go to 1bar spring. a) Rarelyl8 TIAL 46mm 5) Headers and Exhaust: a) Fabspeed Turbo Headers With Heat, and SuperCup Exhaust +200 Cell SportCat - b)B&B Billy Boat Performance Full Exhaust with single mufler - c) Rarelyl8 headers + single outlet mufler with Hooligan Configuration 6) Brakes: I already have big rotors, and will use Pagid pads. 7) Suspension: elephant racing conf, street performance pack 2, no questions about it. Please give me your feedback and let me know If any of these improvements need further modifications. Thanks a lot! Last edited by Mrok; 07-24-2013 at 07:59 AM.. Reason: Problem posting |
Crotchety Old Bastard
The parts you have listed will give vastly different results.
Turbo - choose how you want the power curve and how much power. Intercooler - TK for long neck, I have a new design short neck ready to release. WG - add 1bar spring to OEM or go TiAL. Exhaust - you want bling or performance? Elephant Racing has the suspension covered. |
I'll share my plans (or dreams...) for my car;
already have K27 but like the sounds of the Garrett G35 intercooler TK long neck 1 bar spring in stock WG RarlyL8 headers, with heat, to go with my Hooligan muffler Elephant Racing suspension I think your on the right path, LOL
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
Any other comment?
Come on guys, I am sure you have a lot to share about this topic. |
beancounter
I went with a K27/7200, but now with other mods to my car I will probably go GT35 if/when I have to touch the turbo again.
I don't know that I would spend any $ on an aftermarket intake kit. I don't think its worth anything from a performance perspective. If you really want to ditch the stock airbox for improved access, buy an appropriately sized "Mr. Gasket" aircleaner from Summit Racing and pop it on top of the AFM, deal with the ancillary plumbing issues that result...done! IMHO this is the way to do it if you want to go that route. Me, I like the stock airbox and still use it. Its not that big of a deal to remove. In the many threads on CIS, there have been discussion about modifying the metering plate to improve high rpm fueling, and devices that were supposed to do this. In one of these threads, there has been some speculation that the little cone inside of the stock airbox that sits above the metering plate was purpose-designed to manage airflow across the metering plate and plays a role in the fueling. HTH should I know whether this is true or not, but its plausible. In any case, the stock box is a nicely manufactured piece of OE metal, and it will stay in my car until/unless I convert to EFI.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Hi guys
I am close to start the job en my car.... I am planning to use: * Shortneck Intercooler * K27 Hybrid * Headers * Muffler * 0.9 Bar spring on WG I want to be sure If I need to go with the WUR to make adjustments, as my upgraded configuration so far? SC Cams, But it comes again, If I add the SC cams to my configuration, Do I need to go with WUR o any modification? valve springs or height? Thanks a lot for your help!!! |
I would go long neck intercooler. My reasoning was i couldn't stand that gigantic intermediate BOV manifold cluttering up the engine. That alone was good enough for me. JMHO
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
Turbo Hooligan
1) Definitely go with the GT-35, or any ball bearing turbo over KKK. the response is much better and they flow more air at the same pressure...more power at the same boost level. 2)the Stock intake does a good job, drop in a K&N if you really want to, save some money here. 3)I'd go with the turbokraft intercooler here. Chris makes a quality product! 4)if your wastegate works fine, stick with it theres no gains with a tial if everything is in working order. 5)I'd Use Rarlyl8's stuff here. great quality, sound, and hp gains. The other systems you mentioned won't flow, or sound as well. been there done that. 6) I would add 993 air deflectors at least to the a arms, if not a brake ducting kit. keep em cool! 7) I use rebel racing here but everyone has their own style on how they want their car to handle. Cheers Pete
D-Zug ![]() |
Smart quod bastardus
I can modify your stock OEM wastegate to make it adjustable mechanically without the use of electronic boost controllers and plumbing changes. Provided you supply a OEM wastegate in good working order, I can make it adjustable over a certain range depending upon the spring provided. If you send it with a 1.0bar spring I can send back a wastegate that should span 0.8 to 1.1 bar or if you send it with a 0.7bar spring the range would be roughly 0.5 to 0.8bar. PM me if you are interested in talking about it. I have a k27S turbo in my 3.4 liter with SC cams and it works fine. Minimal lag and very linear power delivery. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
