turbo cut off
Can someone tell me 930 turbo when full throttle will cut of at what RPM?
Old 07-01-2013, 07:53 AM
Bland
unclebilly's Avatar
There are 2 cut offs in your car. One is a rev limiter built into the ignition rotor. This is RPM based and should be at about 6500 RPM. The other is a fuel cut off in an over boost situation that cuts fuel at 1.1 bar of boost. The first cut off is soft, the second is like slamming on the brakes and is not RPM dependent.
Old 07-01-2013, 05:44 PM
my posh 930 turbo fuel cut off at 6000RPM. is it normal?
Old 07-02-2013, 06:10 AM
No. I have taken mine beyond 6k. You may need to check the sender that triggers the over boost
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 07-02-2013, 06:49 AM
Bland
unclebilly's Avatar
What does the boost gauge say when it cuts out?
In cold air (just above freezing) mine will cut out below 4000 ROM becasue the air is so dense.
Old 07-02-2013, 02:26 PM
