Tinkering Pays!!
A/C Hose Fittings: Who makes them locally?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
If that reciever dryer has been open to humid southern atmosphere for more than a day I think you would be better off just replacing it with a new one. The desicant inside may be saturated from absorbing water out of the air by now and evacuating all day long won't boil it and suck it out.
There's nothing special about that one because it has a griffiths sticker on it. You can buy a generic new one that's filled with nitrogen gas to keep it dry with the correct oring fittings for about $30 and you'll be better off with colder air rest of summer. Might be good to use new green AC system orings available from generic auto parts stores, they're cheap, and don't tighten the fittings too much or the orings will squish out and possibly leak. good luck with it. |
Tinkering Pays!!
Jim
Thanks and I did keep the drier plugged (only unplugged for picture). I'll look for a replacement for it, too. Q: do any of the major auto parts stores make the hoses "to fit"?
You should be OK then.
Any respectable AC shop can make hoses for your 930, and chances are great that they will be better than OEM.
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
Tinkering Pays!!
I ordered a Griffiths drier from the host with all the adapter fittings. Should get it b4 the weekend.
Thanks all!
