Allstarmt
High idle
My car is idling at 2500 rpm, I don't know much about my car I just got it. It's a 1986 911 with a 930 turbo conversion. Can I just adjust the idle by the throttle cable?
Old 08-08-2013, 05:19 AM
Turbo Hooligan
try pinching the larger hose on the passenger side of the intercooler to see if your idle drops down. if so then your auxiliary air valve is sticking open
D-Zug
Old 08-08-2013, 07:48 AM
Allstarmt
I pich the house and the idle drops down, thank you so much. Do I need to replace it or is their something else I can do?
Old 08-08-2013, 12:05 PM
Smart quod bastardus
fredmeister's Avatar
You can try to clean the electrical connector sometimes it get corroded or oil fouled.
Other than that, if its sticking internally not much to do but by a new one which costs a left testicle and then some.
I and some other posters have removed it from the system and the car runs without it. Just takes a little more throttle effort on your part during cold weather starts. as long as you dont drive in freezing temps it starts ok without it.
Good luck,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 08-08-2013, 12:15 PM
Allstarmt
I want to thank you so much for your advise. I bought the car and it hasn't ran well and I live in Montana and no one would touch my car. So valve didn't have power to it and it works fine now. Thank you
Old 08-08-2013, 01:33 PM
What about some pictures of the car/interior/engine bay? If you don't know, that's rule #1 here to ge more feedbacks.
Welcome!
Old 08-09-2013, 05:48 AM
Allstarmt
Today 04:18 PM - permalinkAllstarmt
I have a 1986 911 with turbo it was running ok we changes the plugs and now the car won't idle. It starts then dies out. I am try ing advance the timing but their isn't enough space. Can I lift the shaft on the distrubtor to advance the timing so I can time it? You helped me before I thought I would ask to see if you might know. My friend say he wants to lift the shaft and turn it.
Edit Report
Old 08-25-2013, 04:42 PM
mark houghton's Avatar
Wait a minute....it was running fine but with a low idle that you traced to the AAR. Now, you changed the plugs and it won't idle. It goes without saying, do indeed check that you've got the plug wires on the correct cylinders before you go messing with the timing. You should not have to re-index the distributor to get correct timing. Also make sure that you didn't accidentally disconnect one of the vacuum lines on the distributor.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-25-2013, 05:34 PM
