Fuel distributor spring bolts - purpose?
In a moment of temporary insanity, I decided to pull the engine from my 1988 930 in order to fix an annoying unreachable oil leak. I am now in the "while its out" mode of replacing every gasket and marginal hose I can. I have a new gasket for the fuel distributor but before I pull it off, I would like to know what the deal is with the spring loaded bolts that are positioned around the part. What is their purpose and what if anything do I need to do to make sure I don't screw anything up when removing and installing this part. Can't find anything in the shop manual.
Anyone shed any light on this?
Pic below
Old 11-07-2013, 06:09 AM
Thats a good question and I'm not sure but my guess is they are there in case a gigantic mind blowing backfire ever happened in the intake system then maybe those springs would compress a little and let the top and bottom halves of the air flow meter housing seperate a little and let the backfire pressure out instead of blasting the air flow meter sensor plate upwards and damaging it and it's mechanical linkage to the fuel distributor.
I can't think of any other reason for them.
Old 11-07-2013, 09:19 AM
T77911S's Avatar
problem with that is there are i think 4 that are tightened all the way down, no springs.
i was mulling this over too as i was putting mine back on and i did think the same thing.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-07-2013, 09:42 AM
